    Help me solve a mystery
    11 Posts 7 Posters 1.1k Views 7 Watching
    • sdmitchS
      sdmitch
      A new clue in the mystery. If the components exist before the plugin is executed, it runs without a problem. So it is something regarding the initial creation of the components in the plugin that apparently doesn't occur when the Ruby Web Console script is executed.
      http://sdmitch.blogspot.com/
        driven
        if you simply wrap it as a string [ in the .rb file with eval ] and load that, does it work?
        i.e
        eval %Q(# you original code here)
        also, if you post the code it's easier to test...
          Jim
          I would not trust my old Ruby Web Console plugin. There were name-space issues if I remember correctly.
          One simple way to write and test code in SketchUp is to use your favorite editor. Then create a menu or tool button in SketchUp to load the file you are editing. The advantge of a menu is that you can create a shortcut to reload the file. It's a simple, fast, and effective workflow.
          • sdmitchS
            sdmitch
            Apparently the only mystery is why creating components "on the fly" is only partially successful at best.
            • jolranJ
              jolran
              I could think of 2 things related to those errors. You are referencing face.normal in the add instance method. BUT using pushpull on the face after referencing to a variable may delete the original face/faceID or reference what you may call it.
              Also maybe using load definitions from paths might bring more succes than add ?
                Jolran is correct.
                When you use f.pushpull() the original face is lost.
                So when you later try to use a reference to that face ' f' it is a 'deleted-entity' - raising an error...
                But since your container's entities only has the one face with that normal you can re-find the face if needed - or just set a reference to the normal [say as n=f.normal] BEFORE doing the pushpull that deletes the face...
                • sdmitchS
                  sdmitch
                  In this case, I don't attempt to reference the face later. Also, if the plugin doesn't have to create the components, it ran normally.
                  I tried creating a group for each "box" then group.to_component. This was a better but still unreliable.
                  I eventually ended up just adding the "boxes" to a single group rather than making components at all. This then created another problem which was resolved in the test plugin by doing nothing more than simply moving the .add_group statement. I can't imagine why that should make a difference.
                  The good news is that all the gremlins have been eliminated and all is right with the world.
                  • Dan RathbunD
                    Dan Rathbun
                    The old webconsole may have done some initializing of local varibales that your method does not have.
                    Such as:
                    model = Sketchup::active_model defns = model.definitions selset = model.selection
                    etc.
                    Look at the code for the webconsole.
                    I'm not here much anymore.
                    • Dan RathbunD
                      Dan Rathbun
                      Yes you did.. you tried to create a transform using f.normal so that method would likely return nil or raise an exception.
                      Or the add_instance method would return nil making the ci reference nil.
                      Obviously you expect a valid instance or group when you use the explode method, but the reference (that you are calling explode upon,) is referencing nil.
                      Learn to write nil tests / valid test into your code to catch these errors, ie:
                      ci.explode if ci
                        dacastror
                        Is this editor will have the same behavior?
                        404 Not Found
                        (www.alexschreyer.net)
                        the author said it was based on the Ruby Web Console
