    Syntax error upon 2014 startup
    3 Posts 2 Posters 816 Views 2 Watching
      krueger501
      I get the following message upon startup of 2014. Any ideas of how to correct it?
      Error: #<SyntaxError: c:/documents and settings/bob/application data/sketchup/sketchup 2014/sketchup/plugins/iscarnet_dibac/solidsection.rbs:151: syntax error, unexpected ',', expecting ')'
      punto1 = Geom.intersect_line_plane (vector, @plane)
      c:/documents and settings/bob/application data/sketchup/sketchup 2014/sketchup/plugins/iscarnet_dibac/solidsection.rbs:170: syntax error, unexpected ',', expecting ')'
      punto2 = Geom.intersect_line_plane (vector, f.plane)
      c:/documents and settings/bob/application data/sketchup/sketchup 2014/sketchup/plugins/iscarnet_dibac/solidsection.rbs:170: syntax error, unexpected ')', expecting keyword_end
      c:/documents and settings/bob/application data/sketchup/sketchup 2014/sketchup/plugins/iscarnet_dibac/solidsection.rbs:264: syntax error, unexpected ',', expecting ')'
      punto = Geom.intersect_line_plane (vector, @plane)
      C:/Program Files/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
      C:/Program Files/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' c:/documents and settings/bob/application data/sketchup/sketchup 2014/sketchup/plugins/iscarnet_dibac/dibac_cmd.rbs:4928:in register_extension'
      c:/documents and settings/bob/application data/sketchup/sketchup 2014/sketchup/plugins/iscarnet_dibac/dibac_cmd.rbs:4928:in <main>' C:/Program Files/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in eval'
      C:/Program Files/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
      C:/Documents and Settings/Bob/Application Data/SketchUp/SketchUp 2014/SketchUp/Plugins/iscarnet_dibac.rb:10:in register_extension' C:/Documents and Settings/Bob/Application Data/SketchUp/SketchUp 2014/SketchUp/Plugins/iscarnet_dibac.rb:10:in module:Dibac_Extension'
      C:/Documents and Settings/Bob/Application Data/SketchUp/SketchUp 2014/SketchUp/Plugins/iscarnet_dibac.rb:2:in <module:Iscarnet_Extensions>' C:/Documents and Settings/Bob/Application Data/SketchUp/SketchUp 2014/SketchUp/Plugins/iscarnet_dibac.rb:1:in <top (required)>'
        Looks like maybe you installed an old copy of the Dibac plugin--maybe dragged it over from an earlier version of SketchUp? I'd remove it and look for a fresh, updated copy to install. Don't move plugins from an older SU version to SU2014.
          krueger501
          Makes sense. Thanks, I'll download a new Dibec plugin copy.
