    Build Rome
    234 Posts 20 Posters 91.8k Views 20 Watching
    • H Offline
      Hepf
      I still think that Nero's atrium probably had a temple at its center, this is another try ...
      • H Offline
        Hepf
        I've been criticized because I used the standard Sketchup guys in jeans and t-shirt to give scale to the roman views, so I took some images from Alix to populate the renderings, but they do not work that well. I'll have to look for some other solution ...
        And I wonder why the .skp is that big. Thought it would be much lighter ...
        romani.skp
        • H Offline
          Hepf
          Maybe these work better ...
          romani_1.skp
          • H Offline
            Hepf
            Csaba, I am playing with some tools that may interest you, especially 123D catch, that is a free software from Autodesk. I made some interesting 3D visualizations of my wife's excavation and finds. I still use sketchup a lot, as you'll see in the video, made mainly in Poser (the video is just a joke to experiment things), but I am also looking at other software. At the time being I am going crazy trying to learn Blender ...
            3d model of the Palatine hill excavation
            • H Offline
              Hepf
              I am trying my hand at interiors, there goes a WIP on Venus and Rome, still a long way to go ...
              With some help from Poser and Blender ...
              • F Offline
                fluffy82
                Glad to see an update, I was afraid you had abandoned the project!
                I'm a big fan πŸ˜„
                • H Offline
                  Hepf
                  Thanks a lot, Tom. I need fans. There goes the model with all the statues, the volumes are ok, I think. Now it's time for UV's and textures and bump maps, but that will have to wait. I used Blender's decimate modifier on Poser characters for the statues, and I think it works fine, I get some decent figures at very low res and very light. No way I could have built a model with about 26 human figures otherwise ...
                  statua_1.skp
                  • H Offline
                    Hepf
                    I am intrigued by the cistern called the sette sale (seven halls, even if the cistern corridors are nine). Lots of problems in the reconstruction, the lower part is rather straightforward, but the upper part is hellish. I am pretty sure the project was part of Nero's golden house, raised partly after Nero's death by Titus, enlarged and completed by Trajan. A part of the structures on top of it belongs to Trajan, but there is also a late roman extension (IVth century). One of the problems is the access to the upper level. I think the terrain on the northern side was more or less level with it, and that the access was through that side. We'll see.
                    my idea of Nero's project
                    the cistern in Trajan's project
                    the top of the cistern as seen by Google maps
                    starting to work on it.
                    • F Offline
                      fluffy82
                      Carandini reconstructs it something like this:
                      • in the middle of the eastern (curved) side is a basilica-like building
                      • he puts the main entrance there, with a staircase leading down 2-3 meters to the ground level
                      • to the south is a nymphaeum and an oecus
                      • to the north is a flower-shaped triclinium (topped with a large central dome and several smaller domes and half-domes on a lower level; feels quite byzantine)
                      • the series of smaller rooms to the west are a small bath complex
                      • behind the baths, over the "straight" side of the cisterns, a portico overlooking the site of the Domus Aurea / Thermae Traiani, about 10m above street level (with the "arcades" you already modeled below it)
                      Though the North side is level with the surrounding area (on that side) and more suitable for an access to the building, I don't really see where, apart from a door giving out on the long "corridor" leading all the way South...
                      On the other hand, Carandini's solution with a monumental staircase on the curved site doesn't really make sense either...
                      I'm curious what solution you'll come up with πŸ˜„
                      PS I read somewhere that it used to be nothing more than a cistern for Nero's gardens (which makes sense since it has the same orientation as the Domus Aurea), that Trajan relocated the pipes from the gardens - which largely ceased existing - to his baths, building slave quarters on top of it, and that the private house of which we can still see the plan now, is much later - probably Maxentian
                      • H Offline
                        Hepf
                        Yup. I am doing this mainly because I am not satisfied with Carandini's reconstruction. The buildings on top of the cistern belong at least to two moments. One more or less contemporary with the completed cistern (Trajan)and the rest added about IVth century. The problems with Carandini's reconstruction are more than one. One is the access, that staircase doesn't make much sense. The other is the roofing of the flowerlike building, the walls are too thin to sustain a concrete vault, I believe it was wooden. The third is the extension, the edge of the top of the cistern, the part that has fallen off, was very frail. I don't beleve anybody would build something on top of that. And Carandini's reconstruction, based on a central simmetry, goes far beyond even the edge, no way. I think that the whole edge was used just as a sidewalk, no masonry.
                        This is my reconstruction for the first phase.
                        • H Offline
                          Hepf
                          Well, this is what is coming up, not finished yet ...
                          • F Offline
                            fluffy82
                            Interesting how you put the entrance in the octagonal building. Reminds me of the small octagonal side entrance into the Domus Flavia.
                            While the lay-out of the hall itself looks a lot like the one at the Domus Aurea (with the central hall and smaller halls on its side).
                            At first sight, the different parts you constructed seem to bee unlinked. I suppose they will be connected one way or another?
                            • H Offline
                              Hepf
                              Well, they seem to be successive additions, without a straightforward plan. For instance, the corridor between the hexagonal building and the basilica has a rather important role, but gets to be 70 cm. narrow. The plan is there to see, and I had to respect it.
                              One of the main differences with Carandini's reconstruction is in the other apse. I imagined a sort of open air theatre, with the courtyard of the older house as spectators area, and a row of decorative columns as the limit of the scene.
                              • H Offline
                                Hepf
                                This is a flyaround
                                • F Offline
                                  fluffy82
                                  Nice πŸ˜„
                                  • alexandre skA Offline
                                    alexandre sk
                                    very nice
                                    • H Offline
                                      Hepf
                                      Well, I am trying some animations with rendering and textures, using Blender Cycles. All of the model has been built in sketchup, exported to Blender, dressed with textures and rendered in Blender Cycles. These are two stills, still working on the animation, will post it when ready.
                                      inside cella
                                      outside cella
                                      • Bryan KB Offline
                                        Looking good! Really good work, there.
                                        • H Offline
                                          Hepf
                                          From time to time I go back on my model of the Colosseum valley. Here is a new version of Venus and Rome, and the half dome of Maxentius basilica. The half dome was done thanks to the FFD tool.
                                          • 11
                                          • 12
                                          • 12 / 12
