    :Lancaster Lofts:
    21 Posts 10 Posters 2.6k Views 10 Watching
      Roger
      Jason, inside every old man is a young man saying "WTF happened?"
      And my first reaction was YEAAH! Its about time.
      http://www.azcreative.com
      • marked001M Offline
        marked001
        Looks like this project might actually happen. Slowly getting time to update the model/design.... it gained a floor on the front and I put together a quick image for the lobby.
        http://www.revision21vis.com
        instagram: revi21on
        • Chris FullmerC Offline
          The renders are absolutely amazing Jason!
          2 complaints on the design though. The stairs in the courtyard image seem very steep. And the walkway the girl is standing on would NOT work for bare feet. I'm not even sure if it's legal at all! But it is a cool idea.
            marked001
            haha.. yeah, agreed on both. those were quick and conceptual. the stairs were stretched and fudged into place in a rush and the grating is definitely gone now.
            instagram: revi21on
              marked001
              here are the updates to the interior courtyard and rear. it remained pretty true to concept. the window placements aren't ideal but they're not based on the unit layouts; the angles of the faceted facade aren't quite as steep unfortunately; and the whole thing flipped to take advantage of an adjacent party wall.
              instagram: revi21on
              • Bryan KB Offline
                Great updates.
                  marked001
                  Thanks Bryan.
                  instagram: revi21on
                    marked001
                    the inner courtyard of this lost its sawtooth pattern and the front facade couldnt be salvaged, but its more or less intact and construction has started..
                    Front
                    Courtyard
                    Courtyard
                    Updated Render of Courtyard
                    instagram: revi21on
                    • RichardR Offline
                      Richard
                      Nice mate, great project!!!!!!!!!
                      Wondering though about the process there during construction, it looks as though the whole wall is first clad in ply and then the opening cut out? Is this right?
                      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                        marked001
                        Yeah that's how they're doing it...moves along much quicker. Cut it out from the inside after the fact.
                        instagram: revi21on
                        • RichardR Offline
                          Richard
                          Wow! Seems like MASSIVE waste, everything here these days is about waste saving! I know plywood has a tonne of reuse options, but still! 😞
                            marked001
                            What's the other option? Even if you cut it beforehand, you're cutting out the same amount. Otherwise, you'd end up with a bunch of small pieces all over and that can't be good for shear strength.
                            instagram: revi21on
                            • RichardR Offline
                              Richard
                              Mate we tend to design it in! Making sure all panels / windows and opening work at 300mm grids - then the use of a 2400mm or 2700mm sheet can be cut to 600/900/1200/1500/1800/2100 and then the offcut of any sheet has a re positioning option within the wall.
                              I'm just doing this exercise now on a house design where everything works in off shelf SIP panels @ 900 or 1200 wide x 2400/2700/3000 high - then ply linings at 900 wide x 2400 high and built in joinery at 600 and 900 - the total waste will fill a wheel burrow and virtually no onsite cutting.
                              We look at:
                              The cost of excess material, all all reasons of environment, transport and budget.
                              Any waste if it cant be stored, the cost of disposal,
                              Speed of building.
                              The embodied energy in that waste.
                              It also helps too if any post completion off cuts are of these multiple sizes as if they can be stored they will have a purpose later!
                                marked001
                                very cool! and def makes sense to do that with new construction.
                                instagram: revi21on
