    Ruby 2.0 __FILE__ contains incorrect encoding.
    18 Posts 6 Posters 4.5k Views 6 Watching
    • fredo6F Offline
      Thomthom,
      I use FILE in my plugins (actually mostly in the top rb files. I also use $LOAD_PATH in a few places.
      Although many users seem to have no problem (but how many do use a non-ascii username?), it is good to understand if the problem is critical and require an urgent fix.
      What do you think?
        Aerilius
        When it fails, it would show something different (?). This is what I get:
        C;/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/encoding_test/hello.rb
        > Hello World
        require succeeded!
        > Hello World
        load succeeded!
        Forcing UTF-8 encoding...
        require succeeded!
        „Native Windows? Or Linux and Wine?“
        If you had a Linux version of SU (nice!), if SU2014 ran in Wine (nice!), otherwise for all my bug reports I test on a native Windows in a virtual machine. Linux is the luxury and comfort of a Mac with the freedom to work on any hardware. But I have to accept what I can get from SketchUp. I wished SketchUp would become kindof usable on higher-dpi screens. All my other applications scale perfectly. I need patience, at least I'm still with SketchUp after years because I'm addicted.
        • Dan RathbunD Offline
          Dan Rathbun
          Ruby does not support Windows-1258 encoding. It is a known bug.
          SketchUcation Tools 2.5](http://sketchucation.com/forums/viewtopic.php?f)":3vtmbnty]
          @kienhp said:
          Not run in skechUp 2014, why?
          Because Vietnamese encoding is not supported by Ruby yet.
          Bug # 7742 : System encoding (Windows-1258) is not recognized by Ruby to convert back to UTF-8
          One user changed his Regional and Langauge settings to US English to overcome this:
          StackOverflow : Error installing Rubygems on ruby command prompt in Win7
          I'm not here much anymore.
          • tt_suT Offline
            tt_su
            You are logged in as "Administrator" - the issue occur when the username contain non-English characters.
            • tt_suT Offline
              tt_su
              What do you think?
              We're still digging into this. The Ruby Unicode issues under Windows is a deep rabbit hole.
              On one side there is the wrong encoding begin returned for strings that contain UTF-8 data.
              On the other side there is Ruby C Extensions that doesn't load with non-English characters.
              Now, there might be cases where paths with non-english characters will load, if the system code page fits. Though we've not got around to test this yet. But on my machine, which is an English system with Windows-1252 code page - ASCII calls to file functions fail to load non-English characters.
              Now, other users, say Japanese users, might have a Japenese code page configured for their machine and they might experience that having a Japanese username works for them - even though it fails for me.
              Encoding under Windows is a jumble. Under OSX it's all fine because it all UTF-8 by default - even the file functions.
              As I mentioned, we're still digging into this and we'll come back with more info. I wouldn't necessarily start updating scripts right away. We don't know what's the best recommendation yet. But just so you are aware there is a known issue that's being investigated - and it can crop up differently from machine to machine.
              • tt_suT Offline
                tt_su
                @driven said:
                file = __FILE__
                > file_encoding = file.encoding.name
                > puts file_encoding.to_s
                > if not file_encoding.valid_encoding?
                > puts "bad encoding, fixing"
                > data = File.open(file, (file_encoding + ';utf-8')).read
                > else
                > puts "nothing to fix???"
                > data = File.open(file).read
                > end
                I don't quite understand what your code snippet is doing here. It seems like you're mixing up the encoding of the filename string with the encoding of the File object.
                And this: file_encoding + ':utf-8' - what is that doing? Appending UTF-8 to another encoding declaration?
                @driven said:
                so whats going on???
                I don't know. 😕 Can you explain what you are testing with that snippet?
                  driven
                  I have a test file encoded in Vietnamesse(Windows) with CRLF
                  using unix I can see ...
                  > %x(file "path../dev/file•enc•test.rb")
                  path../dev/file•enc•test.rb; ASCII text, with CRLF line terminators
                  In SU...
                  load("path../dev/file•enc•test.rb")
                  UTF-8
                  nothing to fix???
                  true
                  EDIT.... added missing notation [ 'r:' ]
                  file = __FILE__
                  # specify both external and internal encodings
                  data = File.open(file, ('r;' + file_encoding + ';utf-8')).read
                  else
                    driven
                    @tt_su said:
                    I don't know. :? Can you explain what you are testing with that snippet?
                    It was missing a critical piece of notation... [r:] I modified the snippet, will retest later...
                    I was trying to set both external and internal encoding before the read...
                    based on this
                    http://stackoverflow.com/questions/8610100/changing-character-encoding
                      Dan Rathbun
                      NO. John is building a Ruby v2+ IO Mode String.
                      Many of the IO and subclasses (like File,) use it in methods, which transparently call IO::new within themselves. (Examples, are IO.read, File.read, File.open, etc.)
                      So if you read the doc for IO.new, you'll see that wherever you previously used just the filemode ("r" "w+" "rb" etc.,) that argument can now have up to 3 sections:
                      " *filemode* : *external_encoding* : *internal_encoding* "
                      The online doc shows this example (among others.):
                      open("transcoded.txt", "r;ISO-8859-1;UTF-8") do |io|
                        puts "transcoded text;"
                        p io.read
                      So the new mode string above is: "r:ISO-8859-1:UTF-8"
                      Also for better readability, many of these methods that take that 1|2|3 part string (separated by colons,) can instead, take hash arguments, like this:
                      open(
                        "transcoded.txt",
                        ;mode => "r",
                        ;external_encoding => "ISO-8859-1",
                        ;internal_encoding => "UTF-8"
                      ) do |io|
                        p io.read
                      In some cases you can use an or'ed encoding string, like: "BOM|UTF-8"
                      But really ya'll should read the extensive info now listed under IO::new() AND the extensive information at the top of the Encoding class page.
                      • fredo6F Offline
                        OK. I'll wait.
                        But can you confirm that your suggested fix is safe anyway.
                        • tt_suT Offline
                          tt_su
                          That's why I ask that people to hold. We need to perform some testing.
                            driven
                            I started a new encoding bug topic incase it's unrelated...
                            http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=57074#p518534
                            can you all have a look?
