    Ruby 2.0 __FILE__ contains incorrect encoding.
    18 Posts 6 Posters 4.6k Views 6 Watching
      Aerilius
      I don't understand why such encodings are not yet extinct. For me everything is utf8, well except maybe things connected with Windows.
      I just tested on a Windows7 (6.1.7600 Ultimate, 32bit, locale: en-US, VirtualBox), and the encoding test succeeded perfectly in all cases.
      Could we narrow down under what circumstances it fails?
      • tt_suT
        tt_su
        @slbaumgartner said:
        This issue may be Windows only or maybe only certain system configurations. The FILE I get on my Mac is already UTF-8.
        Indeed, it's a Windows issue. It turns out that Ruby isn't declaring itself as a Unicode application despite it's claimed support. And it's not always calling Unicode version of the Windows file functions - it's calling legacy ASCII versions in some scenarios.
        We're working on mapping out where and when this happens.
        Native Windows? Or Linux and Wine?
        What tests did you do?
        I've been working on an updated version of our diagnostics tool to include the encoding data for the environment data.
        So far I see FILE, ENV, $LOAD_PATH and $LOADED_FEATURES yield inconsistent and some times incorrect encoding labels.
        • tt_suT
          tt_su
          Succeeded in what sense? did it succeed in all examples?
          In my testing it fails when you feed strings from FILE directly into require or load. But if you force the encoding then it succeed.
          I consider it a failure that you have to force the encoding. Because that means Ruby is messing up stuff. If the strings where marked with proper encoding it should have been able to correctly transpose the string.
          Another issue is that C Extensions doesn't load with Unicode paths. 😞
          I found a workaround where I was able to call the Win32 API to convert the folder part of the path into short format (DOS 8+3 style) - which indicate that for loading the SO files Ruby calls the ASCII version of the file functions.
          I'll come back with more detail as I've dug into this deeper. But for now I just wanted to give the heads up so you know what'd going on. We've suddenly started to get several reports of this now.
          • Dan RathbunD
            Dan Rathbun
            @tt_su said:
            Well set the default bleepin' encodin' then... 😛
            I'm not here much anymore.
            • fredo6F
              Thomthom,
              I use FILE in my plugins (actually mostly in the top rb files. I also use $LOAD_PATH in a few places.
              Although many users seem to have no problem (but how many do use a non-ascii username?), it is good to understand if the problem is critical and require an urgent fix.
              What do you think?
                Aerilius
                When it fails, it would show something different (?). This is what I get:
                C;/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/encoding_test/hello.rb
                > Hello World
                require succeeded!
                > Hello World
                load succeeded!
                Forcing UTF-8 encoding...
                require succeeded!
                „Native Windows? Or Linux and Wine?“
                If you had a Linux version of SU (nice!), if SU2014 ran in Wine (nice!), otherwise for all my bug reports I test on a native Windows in a virtual machine. Linux is the luxury and comfort of a Mac with the freedom to work on any hardware. But I have to accept what I can get from SketchUp. I wished SketchUp would become kindof usable on higher-dpi screens. All my other applications scale perfectly. I need patience, at least I'm still with SketchUp after years because I'm addicted.
                • Dan RathbunD
                  Dan Rathbun
                  Ruby does not support Windows-1258 encoding. It is a known bug.
                  SketchUcation Tools 2.5](http://sketchucation.com/forums/viewtopic.php?f)":3vtmbnty]
                  @kienhp said:
                  Not run in skechUp 2014, why?
                  Because Vietnamese encoding is not supported by Ruby yet.
                  Bug # 7742 : System encoding (Windows-1258) is not recognized by Ruby to convert back to UTF-8
                  One user changed his Regional and Langauge settings to US English to overcome this:
                  StackOverflow : Error installing Rubygems on ruby command prompt in Win7
                  • tt_suT
                    tt_su
                    You are logged in as "Administrator" - the issue occur when the username contain non-English characters.
                    • tt_suT
                      tt_su
                      What do you think?
                      We're still digging into this. The Ruby Unicode issues under Windows is a deep rabbit hole.
                      On one side there is the wrong encoding begin returned for strings that contain UTF-8 data.
                      On the other side there is Ruby C Extensions that doesn't load with non-English characters.
                      Now, there might be cases where paths with non-english characters will load, if the system code page fits. Though we've not got around to test this yet. But on my machine, which is an English system with Windows-1252 code page - ASCII calls to file functions fail to load non-English characters.
                      Now, other users, say Japanese users, might have a Japenese code page configured for their machine and they might experience that having a Japanese username works for them - even though it fails for me.
                      Encoding under Windows is a jumble. Under OSX it's all fine because it all UTF-8 by default - even the file functions.
                      As I mentioned, we're still digging into this and we'll come back with more info. I wouldn't necessarily start updating scripts right away. We don't know what's the best recommendation yet. But just so you are aware there is a known issue that's being investigated - and it can crop up differently from machine to machine.
                      • tt_suT
                        tt_su
                        @driven said:
                        file = __FILE__
                        > file_encoding = file.encoding.name
                        > puts file_encoding.to_s
                        > if not file_encoding.valid_encoding?
                        > puts "bad encoding, fixing"
                        > data = File.open(file, (file_encoding + ';utf-8')).read
                        > else
                        > puts "nothing to fix???"
                        > data = File.open(file).read
                        > end
                        I don't quite understand what your code snippet is doing here. It seems like you're mixing up the encoding of the filename string with the encoding of the File object.
                        And this: file_encoding + ':utf-8' - what is that doing? Appending UTF-8 to another encoding declaration?
                        @driven said:
                        so whats going on???
                        I don't know. 😕 Can you explain what you are testing with that snippet?
                          driven
                          I have a test file encoded in Vietnamesse(Windows) with CRLF
                          using unix I can see ...
                          > %x(file "path../dev/file•enc•test.rb")
                          path../dev/file•enc•test.rb; ASCII text, with CRLF line terminators
                          In SU...
                          load("path../dev/file•enc•test.rb")
                          UTF-8
                          nothing to fix???
                          true
                          EDIT.... added missing notation [ 'r:' ]
                          file = __FILE__
                          # specify both external and internal encodings
                          data = File.open(file, ('r;' + file_encoding + ';utf-8')).read
                          else
                            driven
                            @tt_su said:
                            I don't know. :? Can you explain what you are testing with that snippet?
                            It was missing a critical piece of notation... [r:] I modified the snippet, will retest later...
                            I was trying to set both external and internal encoding before the read...
                            based on this
                            http://stackoverflow.com/questions/8610100/changing-character-encoding
                            • Dan RathbunD
                              Dan Rathbun
                              NO. John is building a Ruby v2+ IO Mode String.
                              Many of the IO and subclasses (like File,) use it in methods, which transparently call IO::new within themselves. (Examples, are IO.read, File.read, File.open, etc.)
                              So if you read the doc for IO.new, you'll see that wherever you previously used just the filemode ("r" "w+" "rb" etc.,) that argument can now have up to 3 sections:
                              " *filemode* : *external_encoding* : *internal_encoding* "
                              The online doc shows this example (among others.):
                              open("transcoded.txt", "r;ISO-8859-1;UTF-8") do |io|
                                puts "transcoded text;"
                                p io.read
                              So the new mode string above is: "r:ISO-8859-1:UTF-8"
                              Also for better readability, many of these methods that take that 1|2|3 part string (separated by colons,) can instead, take hash arguments, like this:
                              open(
                                "transcoded.txt",
                                ;mode => "r",
                                ;external_encoding => "ISO-8859-1",
                                ;internal_encoding => "UTF-8"
                              ) do |io|
                                p io.read
                              In some cases you can use an or'ed encoding string, like: "BOM|UTF-8"
                              But really ya'll should read the extensive info now listed under IO::new() AND the extensive information at the top of the Encoding class page.
                              • fredo6F
                                OK. I'll wait.
                                But can you confirm that your suggested fix is safe anyway.
                                • tt_suT
                                  tt_su
                                  That's why I ask that people to hold. We need to perform some testing.
                                    driven
                                    I started a new encoding bug topic incase it's unrelated...
                                    http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=57074#p518534
                                    can you all have a look?
