    Add Detail / Geometry or raise Polycount - An Easy way?
    5 Posts 5 Posters 621 Views 5 Watching
    • C
      crdave
      I've recently been venturing into the field of product display rendering. One of the major problems I'm running into is that some models have just too little detail.
      If I were building the whole model from scratch I'd just change the number of sides in a circle or arch, but a lot of times I'm working with models or elements that were done by someone else or for some other purpose. πŸ˜’
      For example, in this picture is a stock blender model that comes with sketchup's pre-installed component library. The hidden lines are visible so that you can see the surfaces used to create the round surface are very low-poly and when zoomed up close the details look very poor.
      Is there an EASY way to add detail to the surface so that the curves are smoother?? (That's to say, without having to re-do the model manually.)
      So much of the talk when rendering is about reducing poly-count but is there a way to increase it?
      Thanks a million!
      -David
      Roundness of the component is very poor up close
      • C
        cbuchert
        You're thinking of something like subdiv levels in 3DS Max, right?
          mac1
          There programs for interpolation and decimation and SU plugins for the same . Do a search for subdivide and smooth and you should get hits for both free and $ su plugins. The $ one has a free trial period. Can you post the model of your post?
          • pbacotP
            The way some of these components are made (unrealistically, with parts all in one component etc.) will still make it "not easy" to fix up sub-par models for PR closeups.
            • KrisidiousK
              Krisidious
              These two might help you out.
              Artisan
              http://artisan4sketchup.com/
              tgi3d
              http://www.tgi3d.com/index.php?Page=Amorph%26amp;
              By: Kristoff Rand
