    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 697.9k Views 121 Watching
    • fredo6F Offline
      @dedmin
      Thanks for signaling. This is actually a bug concerning Curvizard, not FredoTools.
      I fixed it and republished as Curvizard 1.7b.
      • guanjinG Offline
        guanjin
        @fredo6 said:
        @dedmin
        The latest version, the pop-up dialog box displays a blank。
        Be sure to activate the other tools, and then activate it to appear.
        Earlier versions without problems
        • fredo6F Offline
          guanjin,
          This may be related to the Chinese translation. Do you get the error if you switch to English?
          Also, could you check if there is no error displayed in the Ruby console
          • guanjinG Offline
            guanjin
            @fredo6 said:
            guanjin,
            Also, like switching to English,The same problem。
            After activation texture tool display properly activated, see the movie.
            • Fcharly24hF Offline
              Fcharly24h
              On SU 2014 Make the tool bar don't ok for:
              Fredo tools
              curvizard
              Thanks.
              Fcharly24h
              Mon site: Fcharly24h.perso.sfr.fr
              • cottyC Offline
                cotty
                Fredo tools
                curvizard
                Thanks.
                Why not?
                my SketchUp gallery
                  babak
                  Fredo tools
                  curvizard
                  Thanks.
                  Why not?
                  I think what Fcharly24H means is that the tool palette doesn't appear everytime you click on Fredo's toolbars icons with sketchup 2014.
                  For me it happens very often with thrupaint. When I click on the icon, it only triggers sketchup native paint bucket and if I zoom in and out while clicking on and off the tool palette might appears but not necessary.
                  I haven't noticed any problem with other tools though.
                  Thank you Fredo06 for your plugins ! 😛
                    Fcharly24h
                    I don't know!
                    I no problem in verification update, no problem with other plugin of Fredo6
                    in C:\Users\Fcharly24h\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                    I have:
                    new location plugin in Su 2014 Make
                    Icon tool bar ok
                    in SU make 2014 no icon bar for:
                    Fredo tools
                    curvizard
                    in SU make 2013 ok
                    Icon tool bar Su Make 2013 ok
                    Fcharly24h
                      dedmin
                      Object disappears when hitting Esc two times while using ThruPaint
                      SU 2014 Pro, Win 7 64bit SP1 Ultimate
                      Video_2014-03-26_132637.wmv
                      • fredo6F Offline
                        [attachment=0:3relfv60]<!-- ia0 -->Video_2014-03-26_132637.wmv<!-- ia0 -->[/attachment:3relfv60]
                        Escape performs an Undo. So this may be related to making sure it does not go to far back in the Undo stack. I'll check this problem.
                          dedmin
                          See the video.
                          Video_2014-03-26_151418.wmv
                          • fredo6F Offline
                            That's a consequence of enabling 'Auto-Exit' when there is a pre-selection (which is not the default).
                            Maybe I will use this fast-mode only for Make Curve and Explode Curve, and ignore it for other Tools.
                            • fredo6F Offline
                              There must be a bug somewhere, but in general, painting boxes correctly in continuity on all its faces is very tricky.
                              Trying with your model, I noticed the flipping and I'll have a look at it.
                              What I suggest is that you just paint the last face directly, instead of extending it from adjacent faces.
                              • fredo6F Offline
                                NEW RELEASE: FredoTools v1.8c - 17 Apr 14
                                FredoTools 1.8c is a release for MoveAlong v1.0.
                                • KrisidiousK Offline
                                  Krisidious
                                  You soooo rock...
                                  By: Kristoff Rand
                                    Ben Ritter
                                    Thank you again.😄
                                    • fredo6F Offline
                                      NEW RELEASE: FredoTools v1.8e - 20 Apr 14
                                      FredoTools 1.8d is a release fixing a problem in MoveAlong v1.0.
                                      The issue was about moving a selection containing a huge number of entities, as signaled by rv1974.
                                      • OxerO Offline
                                        Oxer
                                        Thanks for the new version and new tool Move Along 👍
                                        I have made a new Spanish Language (Spain) file to include the new tool.
                                        • fredo6F Offline
                                          Oxer,
                                          Thanks. I will integrate in the next release.
                                          Also, for info, all the tooltips for inferences in MoveAlong are actually defined in LibFredo6, not in FredoTools. This is why they won't appear in Spanish.
                                          • OxerO Offline
                                            Oxer
                                            Thanks for the info Fredo. I have made the new Spanish Language (Spain) file to LibFredo6, do you want that i upload it here or in LibFredo6 topic?
                                            • 23
                                            • 24
                                            • 2 / 24
