    [Plugin] FredoTools - v4.6a - 21 Oct 26
    465 Posts 124 Posters 916.7k Views 122 Watching
      dedmin
      Su 2013 Pro, Win 7 64 bit
      Video_2014-02-16_140138.wmv
        rv1974
        dedmin, how do you grab into .wmv?
          dedmin
          (www.faststone.org)
          • fredo6F
            @dedmin
            Thanks for signaling. This is actually a bug concerning Curvizard, not FredoTools.
            I fixed it and republished as Curvizard 1.7b.
            • guanjinG
              guanjin
              @fredo6 said:
              @dedmin
              The latest version, the pop-up dialog box displays a blank。
              Be sure to activate the other tools, and then activate it to appear.
              Earlier versions without problems
              • fredo6F
                guanjin,
                This may be related to the Chinese translation. Do you get the error if you switch to English?
                Also, could you check if there is no error displayed in the Ruby console
                • guanjinG
                  guanjin
                  @fredo6 said:
                  guanjin,
                  Also, like switching to English,The same problem。
                  After activation texture tool display properly activated, see the movie.
                  • Fcharly24hF
                    Fcharly24h
                    On SU 2014 Make the tool bar don't ok for:
                    Fredo tools
                    curvizard
                    Thanks.
                    Fcharly24h
                    Mon site: Fcharly24h.perso.sfr.fr
                    • cottyC
                      cotty
                      Fredo tools
                      curvizard
                      Thanks.
                      Why not?
                      my SketchUp gallery
                      • B
                        babak
                        Fredo tools
                        curvizard
                        Thanks.
                        Why not?
                        I think what Fcharly24H means is that the tool palette doesn't appear everytime you click on Fredo's toolbars icons with sketchup 2014.
                        For me it happens very often with thrupaint. When I click on the icon, it only triggers sketchup native paint bucket and if I zoom in and out while clicking on and off the tool palette might appears but not necessary.
                        I haven't noticed any problem with other tools though.
                        Thank you Fredo06 for your plugins ! 😛
                        • Fcharly24hF
                          Fcharly24h
                          I don't know!
                          I no problem in verification update, no problem with other plugin of Fredo6
                          in C:\Users\Fcharly24h\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins
                          I have:
                          new location plugin in Su 2014 Make
                          Icon tool bar ok
                          in SU make 2014 no icon bar for:
                          Fredo tools
                          curvizard
                          in SU make 2013 ok
                          Icon tool bar Su Make 2013 ok
                          Fcharly24h
                            dedmin
                            Object disappears when hitting Esc two times while using ThruPaint
                            SU 2014 Pro, Win 7 64bit SP1 Ultimate
                            Video_2014-03-26_132637.wmv
                            • fredo6F
                              [attachment=0:3relfv60]<!-- ia0 -->Video_2014-03-26_132637.wmv<!-- ia0 -->[/attachment:3relfv60]
                              Escape performs an Undo. So this may be related to making sure it does not go to far back in the Undo stack. I'll check this problem.
                                dedmin
                                See the video.
                                Video_2014-03-26_151418.wmv
                                • fredo6F
                                  That's a consequence of enabling 'Auto-Exit' when there is a pre-selection (which is not the default).
                                  Maybe I will use this fast-mode only for Make Curve and Explode Curve, and ignore it for other Tools.
                                  • fredo6F
                                    There must be a bug somewhere, but in general, painting boxes correctly in continuity on all its faces is very tricky.
                                    Trying with your model, I noticed the flipping and I'll have a look at it.
                                    What I suggest is that you just paint the last face directly, instead of extending it from adjacent faces.
                                    • fredo6F
                                      NEW RELEASE: FredoTools v1.8c - 17 Apr 14
                                      FredoTools 1.8c is a release for MoveAlong v1.0.
                                      • KrisidiousK
                                        Krisidious
                                        You soooo rock...
                                        By: Kristoff Rand
                                        • B
                                          Ben Ritter
                                          Thank you again.😄
                                          • fredo6F
                                            NEW RELEASE: FredoTools v1.8e - 20 Apr 14
                                            FredoTools 1.8d is a release fixing a problem in MoveAlong v1.0.
                                            The issue was about moving a selection containing a huge number of entities, as signaled by rv1974.
                                            • 23
                                            • 24
                                            • 8 / 24
