View up from bottom?
The standard SU views are top, the 4 sides, and ortho. Any simple way to create a view looking up? Plugin? Is there a built in up view in parallel that I'm missing
?It's there just does not show in the tool bar icons. Either make it a short cut or go to camera views.
Is there any way to make icons for SU commands and assign them to Toolbars? e.g bottom view, perspective, etc
I have a plugin by AlexM called AT Views and it has the bottom view button on it's toolbar. I believe it was called ArchTools. Can't find a download link. Will keep looking. If you can't find it email me and I'll send it to you.
You can use Jim' custom toolbar to add a view up bottom button.
http://sketchucation.com/forums/viewtopic.php?t=10041 -
http://sketchucation.com/forums/viewtopic.php?t=10041Yep. I just found that. Thanks for the replies. I got it going.
