    Quick Selection
    15 Posts 7 Posters 2.0k Views 7 Watching
    • P
      paddyclown
      Hi all, quick question:
      Has anyone else tried to install "quickselection.rb" by D Bur in SU2014 ?
      I put it in the correct plugin folder, I get no error message on starting SU2014, yet it just doesn't show up in the Edit menu (works fine in SU2013) ? And since I have no idea how to invoke it via a ruby console command, I can't force it to run to see if it comes up with an error code...
      Thanks if anyone has any ideas...
      Best,
        It throws up this error message for me. I expect Didier needs to update it.
        Error: #<SyntaxError: <main>: unterminated string meets end of file> -e:1:ineval'
        nil`
        • P
          paddyclown
          oh, ok, thanks; all gobbldy-gook to me πŸ˜‰
          hope there's un update in the pipeline 'cos it a very good plugin...
          • BoxB
            Tig posted a fix for some of Didier's plugins, it may work for this one too.
            Didier needs to rework his rb file for v2014 compatibility and republish it...
            BUT you can do it temporarily for your own use, even though his script is 'packed'.
            Open the file lines2tubes.rb in Notepad, and go to the end:
            Change
            ...}.unpack("m").to_s
            to read
            ...}.unpack("m")[0]
            Save the changes.
            Restart SketchUp.
            The script will then load and work in v2014 !
            This simple fix can be applied to any of Didier's 'packed' scripts that aren't working in v2014.
            These edited scripts will also load and work in earlier SketchUp versions too... πŸ€“
            • P
              paddyclown
              thankyou, that worked for me !
              • P
                paddyclown
                All worked for a while in 2014, but in 2015 and last updated version 2014, I get this error when trying to use the quick selection tool...
                "Starting quick selection...
                Parsing objects with option: All visible objects
                Error: #<NameError: uninitialized constant Set>
                (eval):63:in build_searchable_entities' (eval):495:in quick_selection'
                (eval):691:in qs' (eval):710:in block in <top (required)>'
                -e:1:in `call'"
                any ideas please ?
                  driven
                  Sketchup removed Set it now users Sketchup::Set
                  you could add
                  require('set')
                  at the top of the script...
                  it may then work, otherwise it needs a proper fix...
                  • P
                    paddyclown
                    John, Thanks for the idea... it just made SU bugsplat on start... so i undid the change in order to work; I guess we just have to hope D Bur has a moment to update this plugin which was brilliant !
                      Jim
                      You can replace all occurrences in the script from Set.new with Sketchup::Set.new
                      • P
                        paddyclown
                        Jim,
                        Thankyou ! BingoBongo it works !
                        best,
                          Jim
                          @driven said:
                          would it not be better to do a search and replace changing Set to Sketchup::Set in the script...
                          Yes.
                          I edited my example to remove the code snippet - it's a very bad idea.
                            @driven said:
                            @jim said:
                            This should work.
                            > > if defined?(Sketchup;;Set)
                            > >   Set = Sketchup;;Set
                            > > end
                            I was going to suggest that, but what happens if another ruby has already used require 'set'?
                            That shim should be done in the extension namespace - then it's all fine. It should NOT be done in the global namespace as that will clash.
                              Jim
                              I edited my snippet - it was a bad example without the namespace.
                              Better to just find and replace Set.new with Sketchup::Set.new
                                driven
                                @jim said:
                                This should work.
                                > Edit; removed Jim's example
                                • Dan RathbunD
                                  Dan Rathbun
                                  The easiest fix for Ruby 2 and higher, is to use a refinement that only that file can "see" and use.
                                  I inserted the following at the top of the file (after deleting the Set reassignment):
                                  require 'set'
                                  # Create a refinement for the Set class:
                                  module DBUR
                                    module RefinedSet
                                      refine ::Set do
                                        alias :insert :add
                                        alias :contains? :include?
                                  # Use the refinement:
                                  using DBUR::RefinedSet
                                  By request from @paddyclown, here is the "fixed" file.
                                  It still needs a drastic overhaul, but this will get it working (fingers crossed):
                                  DBUR_QuickSelection.rb
                                  @Didier-Bur ping (I do not know how to send this by PM in this new forum interface.)
                                  I'm not here much anymore.
