    Delete Component Reference
    15 Posts 4 Posters 555 Views 4 Watching
      Dekade
      I am using SU2014. I have a SU drawing where I cannot delete the reference of a component in the 'In Model Library'. Example: I have a component library titled as "Hardware Component Library". The SU drawing has 4 references of Hardware Component "A" showing in the 'In Model Library" as follows: A, A#1, A#2, and A#3. All four of those actual components (A thru A#3) were deleted from the SU drawing. Then I deleted Hardware Component "A" from the Hardware Component Library.
      Here remains the problem - A, A#1, A#2, and A#3 REMAIN LISTED in the "In Model" library of the drawing. How do I get them out of there? I do not want any references of Component "A" showing anywhere; either In Model or in a component library.
      I have tried opening and closing SU but that makes no difference. The references remain.
      This is not the first time over the past few years I have had this problem. However, this is the first time I have addressed it to the forum to find a solution. In all of my other drawings I have just let various references remain.
      Thank You,
      Dekade
      Knowing JESUS CHRIST, and living daily for Him, is a good thing; not an embarrassment.
        Did you try Purge Unused from the Details menu in the Components window? Or from Model Info>Statistics?
        The fact that components remain in the In Model library unless purged is a great feature. If you inadvertently delete a component from the model space you can still retrieve it from the In Model library even after you've closed the file or even shut down the computer.
        Materials and Styles are also saved in their In Model libraries until purged.
        • BoxB Offline
          and have you checked that you don't have the components hidden in the model?
            Good point, Box. Open the Outliner and look for components that may be grayed out. That would indicate they are hidden.
              Dekade
              Dave and Box,
              No I have not tried the purge feature. Let me look for it, try it, and then I'll get back to you. Yes, it does sound like a cool safety feature. I just looked in the Outliner and the parts are not there.
              Thank You,
              Dekade
              • BoxB Offline
                I think you'll find a bit of purging of your old files will slim them down somewhat.
                  Dekade
                  I can't seem to locate the Purge option in the Components drop down. Can you give some further guidance?
                  Thank You,
                  Dekade
                  • BoxB Offline
                    Not components.
                    Go Window/Model info/ Statistics tab click button at the bottom, Purge Unused.
                      Actually it is available in the Components window. It's in the Details menu. Click the little black arrow icon that points to the right on the right edge of the window. Make sure the current library is In Model or it won't be available.
                      • BoxB Offline
                        Once again Dave we have shown that there is usually more than one way to skin a cat.
                        • JQLJ Offline
                          JQL
                          @box said:
                          Not components.
                          And be sure t check "show nested components" is on!
                          www.casca.pt
                          Visit us on facebook!
                            Dekade
                            Got it!!! Thanks for your help. Actually I also just found that I could "right click" then "delete" within the In Model window. I could have sworn I tried that earlier only to find the "delete" to be greyed out. Oh Well. I then tried the Purge in the Details window and it also worked. Very cool cleaner up'er. Lotta drawings to go through now! ๐Ÿ˜„ But, not today. ๐Ÿ˜„ Thanks again you three.
                            Thank You,
                            Dekade
                            • BoxB Offline
                              Tig also has a plugin called Purge All that lets you choose what to purge.
                                Yes, you can right click on the thumbnail and choose Delete but you want to be careful with that one. You can delete all instances of the component in the model, too. I know in this case you said there weren't any instances left in the model space but for future reference keep that in mind. If after running Purge Unused the thumbnail you were expecting to see go away is still there, it would indicate that component is still in use somewhere in the model and you should go looking for it.
                                  Dekade
                                  Further advice well received. I will also look for the Purge plug in. I saw a post below mine that was griping about SU. Every program has its limits no matter the dollar assigned to it. Frankly after 5 years and the need for simplicity in 3D drawing I think SU has really been a great addition for the amateur world. Especially when Sketucation can come through with pleasant down to earth, straight to detail, advice like what I have just experienced. I did not mean to start anything new here. I merely mean to again (and in another way) thank those people that so enjoy the program that they are willing to offer free advice. Fords are Fords. Fords simply just don't come with Rolls Royce interiors. But, you can still have a nice ride through the countryside while in a Ford!
                                  Thank You,
                                  Dekade
