    MAC - Entity Info Window
    4 Posts 3 Posters 876 Views 3 Watching
      ArCAD-UK
      I have tried everything including disabling plugins, reinstalling and rebooting, even just loading a standard template but I can't get the volume to display, I can only adjust the width of the info box. I can modify the shape of other windows but this one seems fixed. ๐Ÿ˜•
      Any suggestions for a fix as I use this for quick quantity take offs?
      O.S.: MAC OS X Mavericks 10.9.2
      Missing Volume field
        driven
        hi,
        your plist entry is probably broken...
        you could bin the whole thing, empty your trash, the do a mac restart...
        or you could try to fix it from 'Ruby Console', may not work, but may...
        copy/past these into 'RC' and hit return/enter
        first see whats already there...
        1:
        %x(defaults read ~/Library/Preferences/com.sketchup.SketchUp.2014.plist EntityInfoPanel_viewsize 2>&1))
        mine returns 250, 118
        2:
         %x(defaults delete ~/Library/Preferences/com.sketchup.SketchUp.2014.plist EntityInfoPanel_viewsize)
        3: run 1 again by using the up arrow twice...
        4: add a sightly silly size...
        %x(defaults write ~/Library/Preferences/com.sketchup.SketchUp.2014.plist EntityInfoPanel_viewsize '200,800')
        5: run 1 again
        Drag the edge triangle and run 1 again, it should be updated...
        YMMV, but report back either way
          I've also had luck fixing this using Reset Workspace in Preferences.
            ArCAD-UK
            @ John. Thanks for the suggestions I do go into panic mode when I see code. The suggestions are appreciated and would have been tried but...
            @ Dave, "Reset Workspace" in preferences seems to have cleared it for now and was simple to implement. I was also relieved to find my custom toolbar remained intact. ๐Ÿ˜ฎ
            Thank you both. Problem fixed.
