    Req: Distribute Spacing plugin.
    29 Posts 13 Posters 2.9k Views 13 Watching
      @panixia said:
      @jeronimoven said:
      hello,
      same problem,
      i unzipped the plugin in the plugin folder,
      i restarted SU,
      but when i click on align and distribute in the plugin menu, i get NO-Thing...
      sdmitch, can you help us ?
      best regards
      same problem here.. i hope there's a way to fix the problem because this plugin looks pretty much amazing.. πŸ‘
      Are you preselecting the objects you want to align?
      • BoxB Offline
        Make sure the folder 'AnD_Support_Files' that is in the zip file is extracted to the plugin folder also. And check that you have the folder security permission set correctly.
        • panixiaP Offline
          panixia
          yes sir.. i do but nothing happens
          • panixiaP Offline
            panixia
            this works, the tool loads and works now, but looks like there is something messy in the dialog box... baybe some other missing file or something? 😐
            • panixiaP Offline
              panixia
              see the 4 radio button for each direction as opposed to the 3 radio button for each row in your screenshot.. also look at the "N/A" slots i think they are not normal.. πŸ˜•
              • BoxB Offline
                Now having played with it a bit I can see it isn't functioning as it should.
                Spacing works and selecting the key component works, but the radio buttons for alignment don't work.
                  jeronimoven
                  hello, bonjour,
                  thanks a lot, that works now !
                  and that is wonderful tool for me,
                  sdmitch , i'll spare a pair of hours each month thanks to your work..
                  if one day, i can do something to thank you.
                  best regards
                  jeronimoven
                    Look the __Ys and _ZY πŸ˜‰ seems it's normal!
                    • sdmitchS Offline
                      sdmitch
                      I am currently on a trip and wont be able to address any of these questions for a few days.
                      http://sdmitch.blogspot.com/
                        ... "acid trip" ... πŸ˜† πŸ‘Ώ
                        • sdmitchS Offline
                          sdmitch
                          NO! Senility!!
                          I have posted a "corrected" version of Align & Distribute plugin on my blog.
                          I had created a second version when some one requested the ability to just distribute, or not aligned, N/A. So when I updated the posting, I unfortunately got the plugin and the support files mis-matched. That is why the radio buttons didn't work.
                          When you click on the plugin link, you will get a list of the contents of the zip file. This is not my choice but just the way Google Drive handles things. Click File and select Download. When extracting the contents of the Zip file, it is only important that the AnD_Support_Files folder be a sub-folder of the folder containing the plugin whether that is the SketchUp Plugins folder or some other.
                          Normally you will want to pre-select the Components and/or Groups that you want to align and/or distribute but, if you don't, you can select the individually by left clicking on them and pressing the Shift key when done. To change the selection, press Shift and repeat the selection process.
                          • 2 / 2
