    [Plugin] Ruby Console+ (3.0.2) – updated 30.10.2017
    61 Posts 18 Posters 44.9k Views 17 Watching
      Aerilius
      That is a Javascript error caused by something in ace.js (you're not getting a popup error because I redirect such errors into the console). When I integrated ace into the webdialog there were a couple of incompatibilities with IE, that I tried to patch. It seems I didn't get that one. I'll try to work-around it. Thanks for reporting!
      • jolranJ
        jolran
        Thank you Aerilius. This one will be used a lot! Very useful.
        I also got that JS error at first launch. Did not hinder me to use the dialog though, so it was surpressed.
        This morning I did not get that error.
        Another thing, I have to launch the plugin twice to get dialog showing. Persistantly. Tried relaunching SU 3 times, all the same. Not a big deal, but someone impatient 😄 might Think the plugin doesent work.
          Aerilius
          The JavaScript error should be supressed in version 2.1.1.
          jolran, I can't reproduce it. When you open the Ruby Console+ for the first time (where it doesn't open), does something appear in the native Ruby Console?
            Is it in the PluginStore? I see no update listed
              Nevermind...I was just too eager on the trigger
              • jolranJ
                jolran
                Hi. Yes there seams to be Typerror during load.
                Ruby console spits this out. Next time I launch dialog opens, and no error message.
                Error; #<TypeError; can't convert Symbol into String>
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Console/Console.rb;297;in `join'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Console/Console.rb;297;in `initialize'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Console/Console.rb;297;in `map'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Console/Console.rb;295;in `each'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Console/Console.rb;295;in `initialize'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Console/Console.rb;90;in `new'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Console/Console.rb;90;in `open'
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/ae_Console/Console.rb;578
                  matt.gordon320
                  Error is no longer coming up for me, just like jolran said. Thanks gents! Looking forward to using what looks to be an awesome console upgrade!
                  • Dan RathbunD
                    Dan Rathbun
                    v2.1.3
                    Testing the namespace feature does not seem to work.
                    when I first open the Console+, and type self, it returns an instance of AE::Console
                    If I try to switch to a module it does not work.
                    Sometimes the text changes in the box, other times it does not and keeps resetting to "global".
                    If I cause an error by typing "module Dan" the output is an exception backtrace, and self becomes main.
                    Other times it starts as main, after attempting to set to some class like String, it is instead within AE::Console.
                    I'm not here much anymore.
                      Aerilius
                      Yes, the namespace feature is the last missing piece that doesn't work in some versions of Ruby. I've fixed it, but not yet published, because I also want to inspect a problem with garbage collection (closed AE::Console instances stay in memory).
                      • tt_suT
                        tt_su
                        I had the same issue with SKUI. After diggin into it it appeared to be the callback handlers that held on to variables from the scope they where defined in causing circular references back to the webdialog. I had to do some awkward workaround to avoid that:
                        https://github.com/thomthom/SKUI/blob/master/src/SKUI/window.rb#L461
                          Aerilius
                          Thanks, I'll look into that.
                          As far as I could analyze my code, it should not permanently keep references of these dialogs. So I've started compiling a patched Ruby version that can reverse-lookup references of an object.
                          • tt_suT
                            tt_su
                            The issue I found wasn't explicitly holding on to variables, but when you create a block in Ruby the outer variables will be available to the block - this implicitly binds objects to that block.
                            So when you create a block for the event handlers of a webdialog you implicitly bind the webdialog variable from the outer scope to the block which ends up creating a circular reference.
                              Aerilius
                              But as far as I know Ruby's gabrage collector is able to release circular references. The object diagram (from the linked ruby-find-references) looks ok. I haven't yet understood fully understood what is happening.
                              So if I avoid that the proc includes a reference to the dialog, I can not easily use instance variables in the proc (without using hacks like __send__(:instance_variabe_get))?
                              • tt_suT
                                tt_su
                                I'm not sure it can release all circular dependencies. Also remember that SketchUp's API classes are defined in C - maybe there's some small differences happening there.
                                I'm not really 100% sure what was going on. I was not pleased with the workaround I had to apply to make SKUI clean up properly, but it did work. I'd be very interested in hearing what you find out.
                                  Aerilius
                                  Big update to version 3.0.2!
                                  For development, see also on github. Contributions welcome!
                                  • Dan RathbunD
                                    Dan Rathbun
                                    When I update via EW (that indicates v3.0.2) I get v 3.0.1 after restarting SketchUp 2016.
                                    (EDIT: okay, I see that v3.0.1 is the EW release. So, n/m.)
                                    Manual d/l from GitHub:
                                    https://github.com/Aerilius/sketchup-console-plus/releases/
                                    Also, on my machine (Win7) with a high contrast custom charcoal system scheme the console is unusable.
                                    Issue #17 filed at GitHub repo.
                                    (Pic attached)
                                      MichaelS
                                      Hello
                                      and thank you so much Aerilius for the update of my favorite tool for coding/testing scripts in SketchUp.
                                      Nevertheless i miss the "reload scripts" button from the previous version.
                                      This was very convenient and fitted my workflow so well...
                                      I use an external editor (Notepad++) and save the files to my plugins folder. Once loaded by typing
                                      load "myscript.rb"
                                      the file was automatically kept in the autoload list. After editing a script and saving the modified file, a button press brought the modified version back into Sketchup for a testrun.
                                      Any chance to get my button back? Please? Or is this functionality somewhere and i haven't found it yet? Of course i could write a <reload_all_my_scripts>-function and call it from the console or add an icon to a SketchUp toolbar. Just thinking this functionality fitted so well into the console (since there's still the autoload list anyway)...
                                      best regards,
                                      Michael S.
                                        Aerilius
                                        The previous "Reload all scripts" button had several flaws:
                                        • it would reload too many scripts, even those that were not changed
                                        • it was a manual action for something that was already automated
                                          I thought since changed scripts are reloaded by default now, there is no need to have a button clutter space, or do something manually that is automated, or offer configurability if there can be a better default.
                                        There could of course exist workflows that I oversaw, but then instead of adding a poor implementation (even for a single user) I'd prefer to find a new solution to the problem.
                                        To understand the problem, how does the automatic script reloading not cover your workflow? When a script under surveillance changes its last modified timestamp, it should be reloaded. Why do you need to manually trigger it?
                                          MichaelS
                                          Thanks Aerilius, i had suspected it should work automatic now and (thought) i had tried but it didn't work. Must have done something wrong.
                                          I will try again when i'm back at my computer.
                                          Michael S.
                                            MichaelS
                                            Ok - checked again and i can't get it to work. What am i doing wrong?
                                            I load my script in the console with
                                            load "myscript.rb"
                                            As expected, the script now appears in the list of monitored scripts.
                                            When i edit the file in an external editor (leaving SketchUp and the console window open), save it and switch back to the console window, my changes are not recognised.
                                            I get an "undefined method" error if i try to add a new function to my script this way and call it from the console.
                                            I'm on Win7, Sketchup Make 2016, 64 bit, ae-console 3.0.2 from PluginStore
                                            Did i miss something?
                                            Grateful for any help.
                                            Michael S.
                                            • 3 / 4
