    Between different Macs plugin works and doesn't work
    48 Posts 6 Posters 2.2k Views 6 Watching
      slbaumgartner
      Garry,
      You might want to try out some of the CORS methods described in this article:
      Cross-Origin Resource Sharing (CORS) - HTTP | MDN
      Cross-Origin Resource Sharing (CORS) is an HTTP-header based mechanism that allows a server to indicate any origins (domain, scheme, or port) other than its own from which a browser should permit loading resources. CORS also relies on a mechanism by which browsers make a "preflight" request to the server hosting the cross-origin resource, in order to check that the server will permit the actual request. In that preflight, the browser sends headers that indicate the HTTP method and headers that will be used in the actual request.
      MDN Web Docs (developer.mozilla.org)
        Garry K
        Jeff and Walt
        I changed this based on what TIG said.
        Please try it
        modified dialog_test.rb
          mwm5053
          This is what I get Garry
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
            Garry K
            Just to be sure - you downloaded the latest dialog_test.rb and line 10 now says:
            @dlg.allow_actions_from_host( 'cabmaker32.com/' );
              mwm5053
              Yes Garry I deleted the other one and installed the the new one.
              2011 iMac
              V2 Twilight
                slbaumgartner
                Trailing slash not needed. Just 'cabmaker32.com'
                  Remove the final / in the domain name. 😕
                    Garry K
                    Jeff and Walt
                    I have now removed the trailing slash from cabmaker32.com on line 10
                    Maybe this will work.
                    Please try it
                    cleaned up the domain address
                      mwm5053
                      Got the same error, sorry wish I could be of more help
                      2011 iMac
                      V2 Twilight
                        slbaumgartner
                        Walt,
                        Do you have the WebKit inspector activated? If not, please open a Terminal window and type
                        defaults write <bundleid> WebKitDeveloperExtras -bool true
                        where you replace <bundleid> with:
                        com.google.sketchupfree8 for v8 Free
                        com.google.sketchuppro8 for v8 Pro (what your info says you have)
                        com.sketchup.SketchUp for 2013
                        After doing that, please run Garry's test script and while the WebDialog labeled "connect to website" is still open, right-click on it and select "Inspect Element" from the popup menu. This will open the WebKit Inspector. The GUI of the WebKit Inspector has changed with version, but look for something labeled "Console" and click it. Please let us know if the Console displays any error or warning messages.
                        Steve
                          mwm5053
                          @ Steve When I right click in Connect to Website all I get is "Reload" but this is what Terminal looks like after pressing return in terminal was that right?
                          2011 iMac
                          V2 Twilight
                            slbaumgartner
                            The Terminal screenshot looks as if you left off part of the command. Did you type the entire line
                            defaults write com.google.sketchuppro8 WebKitDeveloperExtras -bool true
                            I forgot to mention that before entering this command you should quit SketchUp and restart it afterward. Until the default takes hold the right-click menu will only contain "Reload".
                            Steve
                              mwm5053
                              I double checked the terminal and retyped and restated SU still no right click web inspector?
                              2011 iMac
                              V2 Twilight
                                slbaumgartner
                                Missed it again! You typed com.google.sketchup8pro, it should be com.google.sketchuppro8
                                Steve
                                  mwm5053
                                  2011 iMac
                                  V2 Twilight
                                    mwm5053
                                    I don't understand why right click won't bring up Inspect Element?
                                    2011 iMac
                                    V2 Twilight
                                      slbaumgartner
                                      Still typing the command wrong!
                                      t space between Extras and -bool
                                      [edit] Ack, that didn't format right! You left the t out of Extras and attached the - to its end instead of to the front of -bool.
                                        mwm5053
                                        Ya not a very good typist sorry is this right
                                        2011 iMac
                                        V2 Twilight
                                          slbaumgartner
                                          That appears to be right. Did it work?
                                          I'm turning in for the night in a minute. Will check back tomorrow.
                                          Steve
                                            mwm5053
                                            still no inspect element on right click
                                            2011 iMac
                                            V2 Twilight
                                            • 2 / 3
