    Need Help with Vismat
    renderpluginsextensions
    3 Posts 3 Posters 746 Views 3 Watching
      thinkerbell
      Hi. I started exploring vray just recently and I am using it with Google Sketchup Pro 8. I made a test render wherein I applied this wood vismat I downloaded from Vray's Vismat collection. But then instead of having a smooth continuous texture (See image, left side), I end up having a tiled render of the texture (See image, right side). I cannot trace what is causing the problem or which of the settings should I alter in order to fix this. I hope you guys can help.
      [xxl-img:mzbsj206]http://img688.imageshack.us/img688/6446/whyisthewoodtiled.jpg[/xxl-img:mzbsj206]
      In case the image doesn't show, here is the link:
      Thank you so much!
        dlay
        good day
        I'm just a beginner
        may I ask a question and I really need to know if any possibilities to change of dimension of texture in vismat file and how to do that.
        I really sorry because my english so bad
        thanking you
          rspierenburg
          To map a texture like that to a sphere you'll need to use a plugin such as Whaat's UVTools.
          http://sketchucation.com/forums/viewtopic.php?t=23725
