    Dynamic Component trapezoidal Footing
    Scheduled Pinned Locked Moved Dynamic Components
    6 Posts 3 Posters 2.0k Views 3 Watching
      shaan36
      Hello All
      I am finding difficult to create a trapezoidal Footing whose length and width should parametric and the height should remain constant and the top face of the footing should not change.
      Important: Only length and width of footing should be parametric.
      Could some guide me in this i will attached the with this post.
      Regards,
      Shaan
      TowerCrane.skp
        Jim
        Hi shaan,
        Welcome. Hopefully this model will give you some ideas.
        Error 404 (Not Found)!!1
        (sketchup.google.com)
          shaan36
          Thanks Jim,
          I really appreciate & wanna say thanks for the support. it was a bit complex model but at the end i created it with help of reference sample send by you.
          Regards,
          Shaan
            shaan36
            hi jim i wanna ask you one question i this footing component when i open this file all the every element is different but when i insert this file it is come correctly and also it show the green arrow symbol as DC symbol i could i do that check my file...in same file it shows all parameter but when i insert it in different the file i can't see the parameters.
            please guide
            • mitcorbM Offline
              mitcorb
              Hi, shaan:
              Try this link: http://help.sketchup.com/en/article/115544
              It may have the information you are seeking.
                Jim
                please guide
                You are seeing the difference between Importing the file and Opening the file.
                When working with a DC like this which has many sub-components and requires the top-most component to have attributes, you should keep a separate "master" model. I sometimes use WIP (work-in-progress) in the master filename: "dynamic-footing-wip.skp"
                Then when you are ready to use or share the DC, you right-click the DC and select "Save As" giving it the proper name for the DC.
                Or you can upload directly to the 3D Warehouse for use in the Component Browser by right-clicking the component and selecting "Share Component."
                If you try to import the master model, you need to explode it once to get to the parameters. SketchUp automatically "wraps" the imported file in a Component.
