    Curved Staircases
    171 Posts 19 Posters 36.9k Views 19 Watching
    • jeff hammondJ Offline
      same problem still.. 1.0.4 on the left.. web dialog test on the right..
        Garry K
        Thanks Jeff,
        By any chance did you have the ruby console open when you tried the stair maker?
          yeah. sorry- should of mentioned it earlier:
          Error: #<LocalJumpError: unexpected return>
          (eval):551:in `run_startup_dialog'
          from_ruby( 'inside_stringer=Housed|Sawtooth|None&outside_stringer=Housed|Sawtooth|None&inside_option=Has Heel|Has Foot|Both|None&outside_option=Has Heel|Has Foot|Both|None&inside_rail=Guard Rail|Wall Rail|None&outside_rail=Guard Rail|Wall Rail|None&direction=Clockwise|Anti Clockwise&rail_style=Classic|Modern|Round|Square|Standard|Traditional&inside_stringer=1&inside_option=3&inside_thickness=2 1/2"&inside_width=1'&inside_rail=2&outside_stringer=0&outside_option=3&outside_thickness=2 1/2"&outside_width=1' 4"&outside_rail=2&total_rise=8' 9"&risers=14&riser_thickness=1/2"&direction=1&stair_width=3' 6"&radius=8'&degrees=90.0&floor_thickness=1' 1/4"&rail_style=5&tread_thickness=1 1/2"&average_run=10"&tread_bullnose=1/2"&nosing=1"&flare_amount=0"&progressive_flare=3/4"&flare_count=0&open_riser=0' )
          with the dialog test, there's no error but all the stuff starting with 'from_ruby' and on appear in the ruby console..
            Garry K
            I've got some different debugging information in here.
            I've also changed a bit of code that now uses instance variables.
            Please open your Ruby Console and try it and send me back the information.
            version 1.0.5
              adt2
              Garry - I've already sent you this information offline, but I'm repeating it here for the record.
              When I open SU, I immediately get the following error:
              Error Loading File GKWare_StairMaker_Ext.rb
              undefined method `call' for false:FalseClass
              Open the Ruby Console, then select Plugins>Curved Stairs>Stair Maker, and I get this in the console:
              show 1
              loaded 1
              cb1 complete
              closed 1
              show 2
              cb1 complete
              loaded 2
              cb2 complete
              Unless I'm mistaken, the "cb2 complete" shouldn't post to the console until I've hit the OK button, right?
                driven
                Web service error code -21 . Please notify CabMaker32.com.
                  mwm5053
                  Hi Garry I saw this thread when you started it and watching progress. These are my screenshots. I'm on a Mac similar to Jeff's and using SU 8 right know my My Safari build if it helps is
                  2011 iMac
                  SU 2015 Pro, 2017 Make
                  V2 Twilight
                  macOS Sierra 10.12.5
                    Garry K
                    John,
                    You need to edit the Defaults.txt file and insert user and password.
                    Error -21 means "user not on file"
                    The shipped user in the defaults.txt file is "user" and password is "test" and these are not on file.
                    You would have to register on my website which will email you with your password.
                      Garry K
                      Walt,
                      The "http error" comes from the http call to my web service.
                      xmlHttp.readyState == 4
                      and
                      xmlHttp.status != 200
                      I could have returned the status - they mostly talk about time outs etc.
                      I know that the web host site has been experiencing hack attacks today. So it very well could time out.
                        mwm5053
                        Ok so I missed the part about registering on your website so I did just now and still getting "http error" will try later. PS handrail works good. How long is the trial good for?
                        2011 iMac
                        V2 Twilight
                          Garry K
                          The trial is for 30 days. I will reset everyone once I get this working.
                          I am adding a temporary button ( it will mess up the look of the web dialog - but then this is just temporary )
                          I want to rule out if this is a timing issue.
                          Click the load button should reload the information.
                          version 1.0.6
                            Garry K
                            The other thing I should say - is the defaults.txt file gets over written each time. So unfortunately you need to go back in and edit the file.
                              driven
                              you need to allow for easy/simple testing, put them on file and take them off when your done...
                                adt2
                                Garry - No change for me with the 1.0.6 version (although the load error has disappeared, but I think that was due to cruft in my plugins folder, which I cleaned out). Plugin loads fine, and I get the same string in the console:
                                show 1
                                loaded 1
                                cb1 complete
                                closed 1
                                show 2
                                cb1 complete
                                loaded 2
                                cb2 complete
                                Nothing else happens. Data fields are still blank, drop-downs aren't operational, and entering data in the fields and clicking OK doesn't cause anything to happen in the console window.
                                  with 1.0.6 i'm still getting all blank fields and non-functioning drop down menus.. same thing as Andrew above.
                                  ruby console reports:
                                  %(#0000FF)[show 1
                                  loaded 1
                                  cb1 complete
                                  closed 1
                                  show 2
                                  cb1 complete
                                  loaded 2
                                  cb2 complete]
                                  after i push the 'load' button:
                                  %(#0000FF)[loaded 2
                                  cb2 complete]
                                    @ Garry (and Andrew)
                                    see this post ->
                                    this post
                                    [EDIT]not sure why that link isn't going to the direct post.. so scroll down to the end of the page and see the thing about model units
                                      Garry K
                                      I now have Stairmaker handling all of the different units.
                                      The problem was with the single quote used for feet '
                                      If you have feet ' and inches " then I had to deal with the single quote.
                                      I have ruby replace the ' with the back tick ` and have the javascript in the web dialog replace it back as each measurement is put into the controls.
                                      I'm now hoping there isn't anything else wrong with the Mac version.
                                      version 1.0.7
                                        1.0.7 is working for me and my template now 👍
                                          mwm5053
                                          Still having problems here. I installed 1.0.7 and changed username and password in default txt, on 1st click getting "http error" and clicking again getting "can not reach web server"
                                          2011 iMac
                                          V2 Twilight
                                          • jarynzlesaJ Offline
                                            jarynzlesa
                                            sorry but, have I missed something important?
                                            http://www.vizualizaceschodiste.mypage.cz/
                                            • 2 / 9
