    Curved Staircases
    171 Posts 19 Posters 42.5k Views 19 Watching
      Garry K
      Walt,
      The "http error" comes from the http call to my web service.
      xmlHttp.readyState == 4
      and
      xmlHttp.status != 200
      I could have returned the status - they mostly talk about time outs etc.
      I know that the web host site has been experiencing hack attacks today. So it very well could time out.
        mwm5053
        Ok so I missed the part about registering on your website so I did just now and still getting "http error" will try later. PS handrail works good. How long is the trial good for?
        2011 iMac
        SU 2015 Pro, 2017 Make
        V2 Twilight
        macOS Sierra 10.12.5
          Garry K
          The trial is for 30 days. I will reset everyone once I get this working.
          I am adding a temporary button ( it will mess up the look of the web dialog - but then this is just temporary )
          I want to rule out if this is a timing issue.
          Click the load button should reload the information.
          version 1.0.6
            Garry K
            The other thing I should say - is the defaults.txt file gets over written each time. So unfortunately you need to go back in and edit the file.
              driven
              @garry k said:
              The shipped user in the defaults.txt file is "user" and password is "test" and these are not on file.
              you need to allow for easy/simple testing, put them on file and take them off when your done...
                adt2
                Garry - No change for me with the 1.0.6 version (although the load error has disappeared, but I think that was due to cruft in my plugins folder, which I cleaned out). Plugin loads fine, and I get the same string in the console:
                show 1
                loaded 1
                cb1 complete
                closed 1
                show 2
                cb1 complete
                loaded 2
                cb2 complete
                Nothing else happens. Data fields are still blank, drop-downs aren't operational, and entering data in the fields and clicking OK doesn't cause anything to happen in the console window.
                • jeff hammondJ Offline
                  with 1.0.6 i'm still getting all blank fields and non-functioning drop down menus.. same thing as Andrew above.
                  ruby console reports:
                  %(#0000FF)[show 1
                  loaded 1
                  cb1 complete
                  closed 1
                  show 2
                  cb1 complete
                  loaded 2
                  cb2 complete]
                  after i push the 'load' button:
                  %(#0000FF)[loaded 2
                  cb2 complete]
                    @ Garry (and Andrew)
                    see this post ->
                    this post
                    [EDIT]not sure why that link isn't going to the direct post.. so scroll down to the end of the page and see the thing about model units
                      Garry K
                      I now have Stairmaker handling all of the different units.
                      The problem was with the single quote used for feet '
                      If you have feet ' and inches " then I had to deal with the single quote.
                      I have ruby replace the ' with the back tick ` and have the javascript in the web dialog replace it back as each measurement is put into the controls.
                      I'm now hoping there isn't anything else wrong with the Mac version.
                      version 1.0.7
                        1.0.7 is working for me and my template now 👍
                          mwm5053
                          Still having problems here. I installed 1.0.7 and changed username and password in default txt, on 1st click getting "http error" and clicking again getting "can not reach web server"
                          2011 iMac
                          V2 Twilight
                          • jarynzlesaJ Offline
                            jarynzlesa
                            sorry but, have I missed something important?
                            http://www.vizualizaceschodiste.mypage.cz/
                              mwm5053
                              seems Jeff is the only on one to figure it out
                              2011 iMac
                              V2 Twilight
                                Garry K
                                Jaryn Zlesa
                                You need to go to my web site and register. An email will be sent to you with your userid and password. Edit the defaults.txt file and put your userid and password in the file. Plugins/GKWare_StaireMaker/Defaults.txt.
                                Walt M
                                http error means the http connection did not complete. I will modify the code to report back the exact error code.
                                  Garry K
                                  I've made a change at the server to temporarily allow access for user "User" and password "test". After testing this will be removed. At least it allows you to test without having to update defaults.txt for each version.
                                  I've also made a change to stair maker which will give you back the http error code.
                                  Version 1.0.8
                                    mwm5053
                                    Ok so I got the two screen shots to show what I'm getting but after pressing ok with defaults noting happens.
                                    2011 iMac
                                    V2 Twilight
                                      driven
                                      Hi garry
                                      I'm still getting the 'extra' <body''> tag, with 'feet' templates, which prevents the load...
                                      other templates are fine...
                                      You most likely don't see two tags as WebKit always makes tags for any missing or malformed ones.
                                      It doesn't remove the malformed ones, so if they contain js or html control chars, the page will fail to varying degrees...
                                      I cleared my SU cache but sometimes that needs to be done with a restart... will try later
                                        Garry K
                                        Walt,
                                        It appears there can be many different problems that can cause an http error code 0. In the majority of cases it has to do with configuration. Essentially - the host is unreachable. Some google searches suggest that it is a firewall issue.
                                        Try going to your browser and enter this
                                        cabmaker32.com/stairmaker_service.php
                                        If you can reach the service from the browser you should get back
                                        {"code":-11,"text":"invalid format","token":240583372}
                                          oh.. right. that's a different issue (the whole connecting to a website prior to using a ruby.. I mean, what is someone supposed to do if they're not online while drawing??)
                                          the fix I was talking about had to do with model units
                                            mwm5053
                                            @ Garry yes I get {"code":-11,"text":"invalid format","token":240583372}
                                            In Safari
                                            2011 iMac
                                            V2 Twilight
                                            • 7 / 9
