    Curved Staircases
    171 Posts 19 Posters 62.5k Views 19 Watching
    • G
      Garry K
      When I did this test I thought we were good to go with Safari.
      I suppose it is possible that it is a timing issue - which is possible since Safari works asynchronously.
      The difference is instead of hard coding the defaults, the program retrieves values out of variables - that would slow it down.
      I think the next step is to push out some info to the console. I have made a few other changes as I am getting ready to publish the plugin via the plugin store.
      Anyway - I wish I could afford a Mac - then I wouldn't have to rely on you as much. I am grateful.
      A question on the side. Your bio states you are a carpenter. What kind of work do you do may I ask?
      • jeff hammondJ
        i build skateboard ramps:
        • G
          Garry K
          Pretty cool - my oldest son tore his ACL while skateboarding. He was on a pretty steep street.
          I've move the building of the string with all the defaults out of the call back. This should help speed it up.
          I've also put in a few debug messages to the console.
          Since you have a user id and password already I'll just put the plugin here.
          Stair Maker plugin version 1.0.4
          • jeff hammondJ
            same problem still.. 1.0.4 on the left.. web dialog test on the right..
            • G
              Garry K
              Thanks Jeff,
              By any chance did you have the ruby console open when you tried the stair maker?
              • jeff hammondJ
                yeah. sorry- should of mentioned it earlier:
                Error: #<LocalJumpError: unexpected return>
                (eval):551:in `run_startup_dialog'
                from_ruby( 'inside_stringer=Housed|Sawtooth|None&outside_stringer=Housed|Sawtooth|None&inside_option=Has Heel|Has Foot|Both|None&outside_option=Has Heel|Has Foot|Both|None&inside_rail=Guard Rail|Wall Rail|None&outside_rail=Guard Rail|Wall Rail|None&direction=Clockwise|Anti Clockwise&rail_style=Classic|Modern|Round|Square|Standard|Traditional&inside_stringer=1&inside_option=3&inside_thickness=2 1/2"&inside_width=1'&inside_rail=2&outside_stringer=0&outside_option=3&outside_thickness=2 1/2"&outside_width=1' 4"&outside_rail=2&total_rise=8' 9"&risers=14&riser_thickness=1/2"&direction=1&stair_width=3' 6"&radius=8'&degrees=90.0&floor_thickness=1' 1/4"&rail_style=5&tread_thickness=1 1/2"&average_run=10"&tread_bullnose=1/2"&nosing=1"&flare_amount=0"&progressive_flare=3/4"&flare_count=0&open_riser=0' )
                with the dialog test, there's no error but all the stuff starting with 'from_ruby' and on appear in the ruby console..
                • G
                  Garry K
                  I've got some different debugging information in here.
                  I've also changed a bit of code that now uses instance variables.
                  Please open your Ruby Console and try it and send me back the information.
                  version 1.0.5
                    adt2
                    Garry - I've already sent you this information offline, but I'm repeating it here for the record.
                    When I open SU, I immediately get the following error:
                    Error Loading File GKWare_StairMaker_Ext.rb
                    undefined method `call' for false:FalseClass
                    Open the Ruby Console, then select Plugins>Curved Stairs>Stair Maker, and I get this in the console:
                    show 1
                    loaded 1
                    cb1 complete
                    closed 1
                    show 2
                    cb1 complete
                    loaded 2
                    cb2 complete
                    Unless I'm mistaken, the "cb2 complete" shouldn't post to the console until I've hit the OK button, right?
                      driven
                      Web service error code -21 . Please notify CabMaker32.com.
                        mwm5053
                        Hi Garry I saw this thread when you started it and watching progress. These are my screenshots. I'm on a Mac similar to Jeff's and using SU 8 right know my My Safari build if it helps is
                        2011 iMac
                        SU 2015 Pro, 2017 Make
                        V2 Twilight
                        macOS Sierra 10.12.5
                        • G
                          Garry K
                          John,
                          You need to edit the Defaults.txt file and insert user and password.
                          Error -21 means "user not on file"
                          The shipped user in the defaults.txt file is "user" and password is "test" and these are not on file.
                          You would have to register on my website which will email you with your password.
                          • G
                            Garry K
                            Walt,
                            The "http error" comes from the http call to my web service.
                            xmlHttp.readyState == 4
                            and
                            xmlHttp.status != 200
                            I could have returned the status - they mostly talk about time outs etc.
                            I know that the web host site has been experiencing hack attacks today. So it very well could time out.
                              mwm5053
                              Ok so I missed the part about registering on your website so I did just now and still getting "http error" will try later. PS handrail works good. How long is the trial good for?
                              2011 iMac
                              V2 Twilight
                              • G
                                Garry K
                                The trial is for 30 days. I will reset everyone once I get this working.
                                I am adding a temporary button ( it will mess up the look of the web dialog - but then this is just temporary )
                                I want to rule out if this is a timing issue.
                                Click the load button should reload the information.
                                version 1.0.6
                                • G
                                  Garry K
                                  The other thing I should say - is the defaults.txt file gets over written each time. So unfortunately you need to go back in and edit the file.
                                    driven
                                    you need to allow for easy/simple testing, put them on file and take them off when your done...
                                      adt2
                                      Garry - No change for me with the 1.0.6 version (although the load error has disappeared, but I think that was due to cruft in my plugins folder, which I cleaned out). Plugin loads fine, and I get the same string in the console:
                                      show 1
                                      loaded 1
                                      cb1 complete
                                      closed 1
                                      show 2
                                      cb1 complete
                                      loaded 2
                                      cb2 complete
                                      Nothing else happens. Data fields are still blank, drop-downs aren't operational, and entering data in the fields and clicking OK doesn't cause anything to happen in the console window.
                                      • jeff hammondJ
                                        with 1.0.6 i'm still getting all blank fields and non-functioning drop down menus.. same thing as Andrew above.
                                        ruby console reports:
                                        %(#0000FF)[show 1
                                        loaded 1
                                        cb1 complete
                                        closed 1
                                        show 2
                                        cb1 complete
                                        loaded 2
                                        cb2 complete]
                                        after i push the 'load' button:
                                        %(#0000FF)[loaded 2
                                        cb2 complete]
                                        • jeff hammondJ
                                          @ Garry (and Andrew)
                                          see this post ->
                                          this post
                                          [EDIT]not sure why that link isn't going to the direct post.. so scroll down to the end of the page and see the thing about model units
                                          • G
                                            Garry K
                                            I now have Stairmaker handling all of the different units.
                                            The problem was with the single quote used for feet '
                                            If you have feet ' and inches " then I had to deal with the single quote.
                                            I have ruby replace the ' with the back tick ` and have the javascript in the web dialog replace it back as each measurement is put into the controls.
                                            I'm now hoping there isn't anything else wrong with the Mac version.
                                            version 1.0.7
                                            • 6 / 9
