    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 214.1k Views 79 Watching
    • ppoublanP Offline
      ppoublan
      Oxer,
      I made a test on my PC changing show_modal by show, and got the same problem. So I suspect this is linked to the fact that modals webdialog are not working the same on PC and Mac.
      I will need to get advice from experts on this in the developer forum.
      Will come back to you as soon as possible.
      Pascal
      • OxerO Offline
        Oxer
        Thanks for the reply!!
        I sent you a PM two hours ago but it's in the Outbox still. ❓
        • ppoublanP Offline
          ppoublan
          Oxer, (and Mac Users)
          Just published in the Sketchucation Plugin Store a new version that should fix the problem of nothing happens after "New Tree..." webdialog.
          But as I have no Mac available, if Mac users may test and give feedback ?
          Yours
          Pascal
          • OxerO Offline
            Oxer
            Yes, it works now on Mac. πŸ‘
            I tried to send you a PM yesterday, but it's in the Outbox still, so I put here the Spanish Language Translation.
            Spanish Language file
            These are some strings not included in the original language file
            Menu Plugin
            License...
            Registration Popup window
            Unregistered Product
            username:
            keycode:
            unregistered@nowhere.com
            UI.messagebox
            Waiting...
            Working...
            Clic to place tree, Esc to cancel
            Building...
            Building tree...
            Building tree stems...
            Building tree leaves...
            Building tree leaves level 1...
            Building tree leaves level 2...
            Building tree flowers...
            Commit...
            Tree built.
            Building tree proxy...
            Commit tree proxy...
            Tree proxy built.
            Description Tree for trees of previous version
            tree converted from old
              Lee05
              Hi Pascal,
              the plugin is setup into the Plugins folder of Sketchup, as installed by
              plugin store.
              Error still the same.
              Toni
              • ppoublanP Offline
                ppoublan
                Hi Lee,
                Looks like Sketchup does not see the file.
                Check the permissions as described here : http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=56005
                Could you provide a screen capture of your Plugins/3darcstudiotree directory to check the files are there.
                You should have something like this :
                  Lee05
                  Hello Pascal,
                  Here's the print screen. In my opinion the plugin is properly installed.
                  Toni
                  • ppoublanP Offline
                    ppoublan
                    Hi Lee,
                    I do not understand why the file is not loaded by SU if it exists in the right place.
                    To see what happens from SU, can you run this commande from the Ruby Console :
                    File.exists?(Sketchup.find_support_file("Plugins/3darcstudiotree")+"/3darcstudiotree.rbs")
                    Does it return true ?
                    You can also make a try to run SU as Administrator.
                    Pascal
                    • ppoublanP Offline
                      ppoublan
                      [attachment=0:101urpzm]<!-- ia0 -->3darcstudiotreees.txt.zip<!-- ia0 -->[/attachment:101urpzm]
                      Thanks a lot Oxer for that work and pointing out some strings are missing. I will add them to the code in order to be able to localize them as well.
                      Yours
                      Pascal
                        Lee05
                        I run command in Ruby Console, it returns true.
                        SU is running as administrator, error still there.
                        I've installed home the plugin, here works fine.
                        Toni
                        • OxerO Offline
                          Oxer
                          I seen a curious plant in the templates, the tree26 πŸ‘ πŸ˜† πŸ˜† πŸ˜† πŸ˜†
                          • ppoublanP Offline
                            ppoublan
                            Toni
                            hi Toni,
                            So it works fine now ?
                            You copied files to Plugins/3darcstudiotree folder to solve it ?
                            Just want to know if it was a pb of security rights or files beeing in the right folder.
                            Yours
                            Pascal
                              Lee05
                              Hi Pascal,
                              3D Tree Maker works fine on computer from home, there I've installed it from SU plugin store, I did'nt change anything, just leave it how installed itself.
                              On my office computer I still get that error. SU runs as administrator, everything is at it's place and security settings are the same as for all other plugins.
                              When running the command in ruby console returns true also.
                                Have you read and fixed things as this?
                                http://sketchucation.com/forums/viewtopic.php?p=508319#p508319
                                Also your SketchUp installation path looks a bit 'non-standard' ?
                                Did you allow the SketchUp-installer to choose the path or did you 'customize' it ?
                                To check where SketchUp thinks Plugins should be and where they are please type or copy+paste these lines of code in the Ruby Console + <enter>
                                p = Sketchup.find_support_file('Plugins')
                                should return the path to you plugins folder.
                                $LOAD_PATH
                                should return an array of paths, including the same one to the Plugins folder [p].
                                File.exist?(File.join(p, '3darcstudiotree'))
                                should return true if that folder exists in Plugins.
                                File.exist?(File.join(p, '3darcstudiotreeloader.rb'))
                                should return true if that file exists in Plugins.
                                πŸ˜•
                                  Lee05
                                  Hi TIG,
                                  I have read that topic and everything looks ok.
                                  The installation path for SU is a little non-standard on both PC home and office but only at office I got the error. The installation was made from Sketchup Plugin Store v.2.5.1 as other plugins that work fine.
                                  I run the lines of code in Ruby Console it returns at it should, see image.
                                    @Lee05
                                    Your results are fine. πŸ˜„ πŸ˜•
                                    Now recheck that Plugins folder's properties > security against the FULL permissions, as mentioned in my previous post...
                                    The main rbs code is encrypted so we can't see exactly what it's doing...
                                    The tool perhaps writes some temporary data files that it has a permission issue with ?
                                    Can I suggest you contact the maker of the tool directly...
                                    • ppoublanP Offline
                                      ppoublan
                                      @lee,
                                      If the error message is "file not found", I do not think it is due to the content of the file itself. But maybe I'm wrong...
                                      Do not have many other ideas to solve the issue. Here are 2 options you may try :
                                      -delete the file 3darcstudiotreeloader.rb
                                      -delete the directory 3darcstudiotree and all its content
                                      • run SU
                                      • reinstall the plugin from Sketchucation pluginstore
                                        and see if you got the same error
                                      If the problem is still there, copy all the files that are in the plugins directory somewhere else (to be able to put them back later).
                                      Delete all the files in the plugin directory except 3darcstudiotreeloader.rb
                                      Run SU and test
                                      Just to be sure, when you move from SU8 to SU2013, did you reinstalled your plugins or just copied the files from SU8 to SU2013 ? cause I have seen some errors linked to copy of old SU8 files into the SU2013 plugin dir.
                                        Lee05
                                        @ppoublan
                                        I removed everything from plugins menu but 3darcstudiotree folder and 3darcstudiotreeloader.rb and plugin was loaded adn working.
                                        When extensions.rb is back in plugin folder, error is back too.
                                          @Lee05
                                          There should NOT be a extensions.rb file in your 'Plugins' folder at all !
                                          When SketchUp is installed it adds 3 files into the 'Tools' folder - which it needs and which it expects to be in there...
                                          extensions.rb langhandler.rb sketchup.rb
                                          These 3 files should never appear in the 'Plugins' folder.
                                          Check that they are in the 'Tools' folder, and then remove the rogue ones in 'Plugins'...
                                          In SketchUp version 8 there are also several other rb files in 'Tools' - unlike v2013, which should only those 3 rb files in 'Tools' with su_... versions of these extras in 'Plugin's.
                                          The v8 extras will include.
                                          dynamiccomponents.rb sandboxtools.rb shadowstringsfix.rb SolarNorth.rb
                                          Again, in v8 these rb files should not appear in 'Plugins' - they belong on 'Tools'...
                                          Looks like you installation is messed up... πŸ˜’
                                            Lee05
                                            @TIG
                                            Yes, i guess my plugin folder is a little messed up, extensions.rb and sketchup.rb were there. I remove them and everything is fine now, plugin is loaded and works.
                                            Thank you for support.
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
