Dynamic component input format
Hi...any way to make the dynamic component (options as well as attributes) input be able to be done in fractions instead of decimals(inches)....thanks
Yes. Make that setting as needed. Play with the included DC bookcase component to see how it'll work for you.
Thanks....I don't see the component you mention...tried end user units like 22 1/2"...rounds to 22"?
One way is to input into a text attribute, then convert the contents using the value and string functions
updated,,,
Attached a component with a calculation group (no size, could set hidden) for lenX,lenY,lenZ
(better labels than last)Philip
