    Export to .dwg, the lines are out of scale
    5 Posts 3 Posters 313 Views 3 Watching
      Skitse
      Hi there
      As a new member of this site, let me first introduce my self.
      I started at the University in Aalborg denmark, the summer of 2012.
      I'm planing to become an industriel designer.
      Right now I'm in the middle of a project, where we have to create a small clouster of 6 houses.
      But here is my problem...
      I have used the plugin called "Flattery" and made a 2d object, from a 3d objekt.
      I would like to export my object to a .dwg file, so I can work with it, in AutoCad 2014.
      BUT, every time I try and export the file, the lines in AutoCad are oversized, an therefor I can't us them. I have deleted the lines and replaced them with the "real" lines, but this takes forever!
      How did I do it?
      1. I got the object placed between the x and y axes
      2. I choose parallel perspectiv
      3. Choose top view
      4. Export - 2d object to dwg
      5. Name the file
      6. Open in AutoCad 2014
      7. Bite my tongue in frustration
      What am I doing wrong?
      I can try and upload a pictur if that would be of any assistance?
      Have a nice day/ evening
      Skitse
        Skitse
        Here is a picture where the first part is from Sketchup and the second part is from AutoCad.
        Sketchup 2013 vs. AutoCad 2014
        • mitcorbM Offline
          mitcorb
          Hi, Skitse:
          I could not find anything in the Sketchup Knowledge Center pertaining directly to line quality in the export, but I am guessing that you need to change your template/style for the source drawing to something without endpoints and fat lines. Or possibly change to Wireframe mode.
          There have been some discussions relating to this in the forums. I will check around and try to get back. In the meantime, maybe someone else can offer some solutions?
          EDIT: I went to the search box at the very top of this page. I typed "export to dwg" and enter.
          A page came up with possible related links. Here is one: http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=44077#p393047
          You may want to read some of the others, in case this does not offer any solution.
            Charlie__V
            Skitse,
            Have you checked .dwg your export options...perhaps under profile lines.......Export...... polylines and widthis selected?
            Charlie
              Skitse
              Hi again
              I did a new clean install of sketchup, and that seems to have done the trick 😄
              I have tried 2 different files, and both came out with the right type of lines.
              I don't know if it was setting that was wrong, that was reset in the new installation, or something went wrong after the first install.
              @mitcorb, I tried different styles, and after setting the line type to 1 in some of the styles, the line got thinner, but it was still not the correct linetype in AutoCad, but thank you for your answer 😄
              @CHARLIE__V, I tried all different line types in the option, but that did'nt help. Thank you for your reply.
