πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
How to distribute items along a line?
7 Posts 6 Posters 19.3k Views 6 Watching
  • N Offline
    Nstocks
    Hello,
    I would like to distribute several windows along a line, but they all need to be equally spaced apart. I have created the lines that they need to go along, and the window is to the correct dimensions.
    Thank You
      Daniel
      There are two ways:
      1. Select the object. Press the "Ctrl" key and then use the Move/Copy tool to copy the object to where you want the last object to be. Type in "/#", where # is the number of desired divisions. SU will divide the distance between the first and last objects by that number and place equally spaced objects.
      2. If you know the distance between the objects, select the object, press "Ctrl" key, and then use the Move/Copy tool to copy it that distance. Type in "#x" where # is the number of repetitions (in addition to the first object).
      The above is for Windows operating system. I think for Mac you press the "Option" key in lieu of the "Ctrl" key.
      My avatar is an anachronism.
      • W Offline
        wyatt
        If it's a curved line, try PathCopy.rb at Smustard: http://www.smustard.com/script/PathCopy
        • N Offline
          Nstocks
          Thanks for the responses, they work perfectly !
            KXI System
            I amaze a whole lot of people with that trick, I seem to be moving a copy of a power line but then...
            Viola! instant line of poles!
            Getting the perfect sig is hard...
            Google it!
              djh
              A valuable tip. Thank you.
              DJH
                And for more fun : Components Stringer by Chris Fullmer πŸ˜‰
                Advantage: your have 3 possibilities of the size of the Components along the lines: Uniform, Stretch or none!
                And they follow the "orientation" of the curves - lines! πŸ€“
                • Random Painter always by Chris Fullmer πŸ˜‰
                  You can of course take also a simple divided line with it! πŸ˜„ (Right Click on the line / Divide)
