    [plugin] multiple dimension tool
    8 Posts 3 Posters 2.6k Views 3 Watching
      glro
      The Sketchup original dimension tool adds dimension between 2 points only at a time
      Here is a plugin, that adds dimension between 11 points max in a row
      new version 1.01
      mult dim tool screen copy
      a video:
      https://dl.dropboxusercontent.com/u/52719814/videos/multiple_dimension_tool.webm
      Only a part of the code is original; it is mostly a compilation of different ideas:
      TIG suggestion somewhere (i don't remember the thread) to use a dimension as a component and scale it
      Eneroth's code from 3D Rotate Tool, to set the points
      http://extensions.sketchup.com/en/content/eneroth-3d-rotate-tool
      J FOLTZ's inputbox.rb, to store the previous value in the registry
      http://sketchucation.com/forums/viewtopic.php?t=19103
      it is included in mult_dim_tool folder
      To use the plugin:
      Launch it from the plugin menu "mult_dim_tool"
      clic on the points (11 max)
      press the "space" bar when enough points have been set
      a dialog box pops up to choose the leaders length (in meters)
      clic OK and the dimensions are added to the model
      There are limitations:
      in meters
      PC only
      10 dimensions at a time maximum
      I needed such a plugin to indicate the columns foundation position
      Maybe somebody can find it useful too
      I tried to follow the rules; the plugin is packed using .rbz convention
      Hope i didn't write anything wrong that would mess up the plugins folder
      If so, i am ready to correct
      • kmeadK Offline
        kmead
        Unfortunately it won't load on my Mac OSX latest version of SU, below is the Load Error screen:
        Error Loading File /Users/kmead/Library/Application Support/SketchUp 2014/SketchUp/Plugins/mult_dim_tool/multiple_dimension_tool_loader.rb
        Error: #<LoadError: cannot load such file -- inputbox>
        /Applications/SketchUp 2014/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:45:in require' /Applications/SketchUp 2014/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.0/lib/ruby/2.0.0/rubygems/core_ext/kernel_require.rb:45:in require'
        /Users/kmead/Library/Application Support/SketchUp 2014/SketchUp/Plugins/mult_dim_tool/multiple_dimension_tool_loader.rb:8:in <top (required)>' /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require'
        /Applications/SketchUp 2014/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load' /Users/kmead/Library/Application Support/SketchUp 2014/SketchUp/Plugins/multiple_dimension_tool.rb:17:in register_extension'
        /Users/kmead/Library/Application Support/SketchUp 2014/SketchUp/Plugins/multiple_dimension_tool.rb:17:in `<top (required)>'
        Thanks, hope this helps you get to the next iteration.
        Karl
        I created Dilbertville, sorry about that...
        • TIGT Online
          KArl
          You also need to install inputbox.rb by Jim Foltz's - from his site.
          It was an experimental helper script/class, which a few users have integrated with their own plugins.
          It is bad form not to explain clearly to others that it is essential, and where to get it from...
          FYI it can be downloaded directly from here...
          http://sketchuptips.blogspot.co.uk/2008/03/inputbox-class.html
            glro
            @tig said:
            KArl
            I am sorry but you are wrong on this TIG
            If you read again what i wrote, you'll see this:
            "> J FOLTZ's inputbox.rb, to store the previous value in the registry
            http://sketchucation.com/forums/viewtopic.php?t=19103"
            i did mention inputbox.rb
            I mentionned you also, by the way; because the first idea is yours; thank you for your help
            • TIGT Online
              @glro
              You are correct in that you have 'almost' explained it in your post.
              However, what it says is that you have used ideas from others, and not that the user MUST get and install another script: the text should have been bolder/red etc to draw attention to it - many downloaders are very lazy and will never read instructions anyway - let alone ambiguous ones:roll: - also a direct link would have been helpful.
              I have edited your post for you...
                glro
                @tig said:
                @glro
                OK
                i assumed people would not be lazy, and english is not my native language
                i'll do better next time
                anyway, i discovered how inputbox.rb is useful, because it enables to store the previous answers in a dialogue box, without having to write it down in a file outside the "program files" folder
                • TIGT Online
                  FYI, these are the main ways to store data...
                  @variable in a Module, remembered for reuse that session.
                  @@variable in a Module or Class, remembered for reuse that session.
                  For each model - saved across opening for any user:
                  Sketchup.active_model.set_attribute(dictionary_name, 'key', value) Sketchup.active_model.get_attribute(dictionary_name, 'key', optional_default_value)
                  which is stored in the model.
                  For every model opened in SketchUp by that user:
                  Sketchup.write_default(section_name, key, value) Sketchup.read_default(section_name, key, optional_default_value)
                  which is stored in the PC's 'Registry' [or 'plist' on MAC].
                  Alternatively settings for a complex tool can be saved into a file, per User.
                  This file[s] can be made/updated/read, located in a custom-folder for that plugin, which you make [if it doesn't already exist] in the ENV['TEMP'] folder for a PC - on a MAC ENV['TMPDIR'] - use RUBY_PLATFORM.downcase=~/darwin/ to see if it's a MAC - or similar User accessible folder.
                  Don't use a folder within Plugins as it might not be fully accessible to the User.
                    glro
                    I updated the plugin
                    http://sketchucation.com/forums/viewtopic.php?p=505840#p505840
                    [mod=:mjnka2at]I added the correct link - taken from the small tag below the title of the first-page.
                    TIG[/mod:mjnka2at]
                    11 points instead of 6
                    in a horizontal plane only
                    but following any direction
                    J FOLTZ's inputbox.rb is included in the folder.
