    CLOSES GROUP AFTER MODIFICATIONS
    4 Posts 4 Posters 304 Views 4 Watching
    • B
      bossismax
      what does that go with this process?
      Please I need your help. Thank[highlight=#ffbfbf:1c0a9xxl][/highlight:1c0a9xxl] you.
      • cottyC
        cotty
        We need more [and clearer] information to let us help you with your problem!
        my SketchUp gallery
        • Jean LemireJ
          Jean Lemire
          Hi Bossismax, hi folks.
          To close a group or a component, you can do one of the following:
          1 - Click outside the bounding box (made of dotted lines) of the group or component.
          2 - Right click on empty space or on a geometry that do not belong to the group or component to bring up a contextual menu and choose Close Group or Close Component.
          Notice that if you are editing a group within a group, you get up one level in the hierarchy. You will then be in the parent group containing a subgroup. Redo the closing to get back to the root of the model. If you have, for example, 3 levels of nesting, you will need to do that 3 times to get out of a sub subgroup. Using the Outliner allows you to get back to the root of the model with one double click.
          Read the help about the Outliner Window to see more about groups and components and how to navigate through a complex setup.
          Just ideas
          • Wo3DanW
            Wo3Dan
            1. and 2) as mentioned above
            1. Hit [ESC] once per each level moving up.
