    A Little Stool in Red Oak
    39 Posts 12 Posters 5.3k Views 12 Watching
      Yeah, I can see that. I guess the trick is to change what the brain thinks it sees. I could take the easy way out and change the flooring to something hard like tile of wood.
      • BoxB Offline
        It is that damn carpet, I tried everything, bumps, lighting, holding my mouth right, a rabbit, nothing I could do made the carpet work. It's always the way, nobody sees the good stuff just the problems.
          A whole rabbit? That's really trying!
          Hmmm.... I guess I'll tear out the carpet and put down something else.
          Nice stool, though.
          • N Offline
            nickchun
            Yes and the original wood textures are great. How do you go about getting even lighting when you take the photos?
              Nick, I think it's pure luck. It doesn't always work out that way.
              Actually it probably isn't very even end to end. It matters most that it's even across the width of the board. My texture images cover 6 to 14 feet of a board so I don't need the material to repeat along the length like the typical square texture images must. Because of the size of the texture and because it is supposed to represent real wood, I have no use for seamless textures. Usually I'll have two or more boards from the same tree and I try to make them as similar in exposure as I can get.
                Four legs are not hyper stability for this sort of thing?
                  What difference does that make? It would be stable enough. If I'd made it with 3 legs it wouldn't have been true to the original design.
                  • BoxB Offline
                    Is there a stool plugin? Hmm the idea of pluging a stool in makes my eyes water.
                      No fair! I had a mouthful of coffee.
                        Less wood! πŸ˜‰
                          Less wood! πŸ˜‰
                          More difficult to make.
                            Economy / Rentability / Difficulty
                            a difficult choice! πŸ˜‰
                            • BoxB Offline
                              Easy, sit on floor.
                              • gillesG Offline
                                gilles
                                There is: πŸ’š
                                  The cost difference to make two of these stools with four legs or three isn't much. I'm not planning to rent them to anyone and we have flat floors in our house. Nearly every other seat in the house has four legs, too, and no one ever has any difficulty sitting on them. The simplicity of building them with four legs outweighs any benefits gained by making them with three legs.
                                  Gilles, that one would be hard on our maple floor. πŸ˜‰
                                    This last one is more for milk cows or sheeps! πŸ˜„
                                    • N Offline
                                      nickchun
                                      @dave r said:
                                      Nick, I think it's pure luck. It doesn't always work out that way..
                                      looks like I'll have to build that light tent after all
                                      • Bryan KB Offline
                                        Classic. πŸ‘
                                        • 2 / 2
