Changing part of a geometry from dc attribute
Scheduled Pinned Locked Moved Dynamic Components
7 Posts 3 Posters 1.4k Views 3 Watching
    dumarjo
    HI,
    I try to modify a DC part. I have a polygon, and I would like to change some part of the polygone with DC attributes.
    I have put in attachement the skp of the polygone I would like to change.
    I would love changing th x1 and y1 from the attributes.
    Is it possible to do this ?
    Regards
    Jonathan
    testDC.skp
      You could divide the panel into two different components and change the dimension of each to change X and Y. The downside is if you want to generate a cutlist from the model, the panel will be shown as two different parts rather than just one.
      How many different toe kick dimensions would you have? If it's only two or three, you could make different components each with a different notch size and then choose which one to show and which to hide. I did that some time back with a dining table that is available in three different lengths. Since the shape of the table top couldn't be scaled, I just put each of the three different tops in the Dynamic Component. When the user selected the length of the table, the appropriate top was displayed. The benefit of this is that the top shows as a single component in the model.
        dumarjo
        hi,
        This is the conclusion that I came of. The toekick shouldn't be too much different from one cabinet to others.
        From your comment, we can't do this ith DC directly ?
        Regards
        Jonathan
          pcmoor
          Hi Jonathan
          If you decide to make the DC using sub groups, then I recommend you make them out of solids so that if you want to 3D print, CAM or BOM, then you can convert to single object using the outer shell command (right click for context menu).
          So hide rather than delete shared faces and lines. Where you require an outline use a cubic shape with one or two axis length set to zero and hide other lines where necessary. for multi hidden sub groups that are not part of finish have all their length attributes =0 and position so it will become part of the final shape on either explosion or use of the outer shell command. (sample attribute in form ...X =if(Hidden,0,parent!LenX-LenX)
          attached sample
          The first side is made of two groups with no hidden geometry, on using the outer shell command they become one, the obvious common lines are deleted.
          The second is more involved, using 3 solid groups, it likewise can be changed to a single group of geometry using the outer shell. The outline is a solid group with its Z length set to "zero" (very small)
          Lots to think about?
          Cheers
          Philip
          two examples
            dumarjo
            Well i' don't quit understand what you said 😄
            I see in the sample that all 3 model are a multipart. The first one is the first thing I have in my head. The easiest one. When I try to use the cutlist plugin, it' see 3 part. That's normal. I If I use the outer shell is working. The problem is when we want to have more than one par in a component (like a base cabinet) we have to go thru each cabinet, edit it and to the outer shell command for all the panel.
            Probably we can overcome this with a ruby command.
            Cheers
            Philip
            yes this is alot !
            thanx for your time and effort to help me with this !
            Regards
            Jonathan
              dumarjo
              Another question. Is it possible to add an part created in ruby to an component ?
              I did a ruby script that create this part, but I wonder if this can be included in a DC component ?
              I see that I can call a ruby script from the DC, but I have not been able to add this part to the DC itself. I can only create the part and add it to the model and not to the the selected component.
              I'm new to ruby too so it's a little bit complicated.
              Here what I did to create the part from the ruby script.
              require 'sketchup.rb'
              class DCFunctionsV1
              protected
                def createside(param_array)
                  mod = Sketchup.active_model # Open model
                  ent = mod.entities # All entities in model
                  sel = mod.selection # Current selection
                  lheight = param_array[0]
                  llength = param_array[1]
                  ltoeheigth = param_array[2]
                  ltoelength = param_array[3]
                  lwidth = param_array[4]
                  printf("heigth = %d\n", lheight)
                  printf("length = %d\n", llength)
                  printf("toe heigth = %d\n", ltoeheigth)
                  printf("toe length = %d\n", ltoelength)
                  printf("width = %f\n", lwidth)
                  # Create a series of "points", each a 3-item array containing x, y, and z.
                  pt = []
                  pt[0] = [0, 0, 0]
                  pt[1] = [0, 0, lheight.to_f]
                  pt[2] = [llength.to_f, 0, lheight.to_f]
                  pt[3] = [llength.to_f, 0, ltoeheigth.to_f]
                  pt[4] = [llength.to_f - ltoelength.to_f, 0, ltoeheigth.to_f]
                  pt[5] = [llength.to_f - ltoelength.to_f, 0, 0]
                  new_comp_def = mod.definitions.add("BCSide") ;
                # Call methods on the Entities collection to draw stuff.
                  new_face = new_comp_def.entities.add_face(pt) ; # returns a Face
                  new_face.reverse! if new_face.normal.z < 0 ; # flip face to up if facing down
                  new_face.pushpull(lwidth.to_f)
                  trans = Geom;;Transformation.new
                  mod.active_entities.add_instance(new_comp_def, trans) ;
                  #UI.messagebox("heigth = " + lheight.to_s)
                  return "ok"
                pcmoor
                With regards ruby it would pay to post your enquiry in the developers' forum to get more responses
                Personally I am in a similar position, learning ruby, building DC to be used with code, interest is framing
                With regards swapping, and cut list
                consider the example again with a group of Right end components
                if you copy the side DC and replace the geometry within one of the Right ends with it, set the DC to required parameters, then right click, outer shell then explode, all updated and can be seen as complete in cut list
                Cheers
                Philip
                sides.skp
