    [Plugin] CleanUp
    974 Posts 217 Posters 834.0k Views 217 Watching
      gbu
      @box said:
      @dave r said:
      There's a Download button in the first post of this thread. Click that and then the red Download button on the next page. Change the file's extension to .ZIP, extract the contents of the zip file and place them in the Plugins folder making sure you maintain the file structure. Make sure you also get the TT_Lib support files as indicated in the first post.
      Is the red text not what you were after? A very clear indication of where to download the file you wanted. So I don't believe Dave needs to improve his reading skills.
      Where in the first post is the download button? Explain with a screenshot if necessary.
        gbu
        @cotty said:
        Maybe 4 answers by global moderators, 2 from the plugin author and 1 of a Top Sketchucator are not enough help... we have to work harder!
        Another sarcastic comment- its really not necessary. The author of the plugin answered my query with no fuss at all.
        Thanks for the insight.
          Sheesh!
          • BoxB Offline
            Here,
              gbu
              @dave r said:
              [attachment=1:yqzcc5n7]<!-- ia1 -->dl.png<!-- ia1 -->[/attachment:yqzcc5n7]
              [attachment=0:yqzcc5n7]<!-- ia0 -->dl2.png<!-- ia0 -->[/attachment:yqzcc5n7]
              Sheesh!
              didn't see that- must be going blind- apologies.
              ...or working too hard! ok, fine people of sketchucation, thank you for your help.
              • tt_suT Offline
                tt_su
                If you install the PluginStore you can search and install all the SCF hosted plugins from within SketchUp. And it'd be a uniform UI so you'd always find the Download button in the same place instead of the random positioning and presentation of the forum threads.
                  gbu
                  Thanks, but as I said previously the PluginStore says only for version 8. I have version 7. If that is not the case I'd appreciate a note on how to download version 7 plugins from within Sketchup.
                  edit: message says: Parts of this process only work with Sketchup >= v8M2.
                  • tt_suT Offline
                    tt_su
                    Oh right - it uses the RBZ install feature. Yea - then you have to do it the ol' manual way.
                    • BoxB Offline
                      Just to be clear, the Sketucation store plugin is saying only certain features work with SU8, not the plugin itself.
                      The auto install part of the store doesn't work with SU7.
                        gbu
                        ok, thanks for confirming- guess its time to upgrade soon. Used this the first iterations of sketchup intensively back in 2000/2001 for a few years, then concentrated on 3dmax.
                        But for quick and easy nothing beats it.
                          gbu
                          righto, thanks
                            blauga
                            Hi Thomas. I use Cleanup with Sketchup 2013. I noticed that occasionally, some faces disappear. I have uploaded a sample model (actually an extract of a sofa model). It contains to cushions. The one with holes has been treated with cleanup, resulting in missing faces. The other one has not been treated yet.
                            Any idea ?
                            coussin.skp
                            • tt_suT Offline
                              tt_su
                              What settings did you use? I just ran it with default settings on a fresh installation of SU and no faces were lost.
                              • E Offline
                                expresso405
                                @TT;
                                I have a file that generates lots of errors. (probably down to my sloppy drawing practices). 😳 ...
                                Do you still want example files that generate errors sent to you?
                                Thanks for a great plugin! πŸ˜„
                                  Depends on the errors. Does the model have lots of small faces/edges?
                                    saucerful
                                    Hi Thom, thanks for this excellent tool.
                                    I was hoping you could help me get it working in Linux under wine. I saw the discussion many pages back about wine but that was a different error. I am using SketchUp 8 and the latest TT_Lib 2.9.8 and Cleanup 3.2.1
                                    After installing TT_Lib and restarting I am getting a dialog saying
                                    Error Loading File C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb
                                    uninitialized constant TT;;GUI;;ToolWindowError Loading File TT_Lib2.rb
                                    uninitialized constant TT;;GUI;;ToolWindowError Loading File C;/Program Files/Google/Google SketchUp 8/Plugins/tt_cleanup/core.rb
                                    uninitialized constant TT;;GUI;;ToolWindowError Loading File tt_cleanup.rb
                                    Meanwhile in the terminal I see
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2.rb;19; warning; already initialized constant PLUGIN_ID
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2.rb;20; warning; already initialized constant PLUGIN_NAME
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2.rb;21; warning; already initialized constant PLUGIN_VERSION
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;27; warning; already initialized constant BB_LEFT_FRONT_BOTTOM
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;28; warning; already initialized constant BB_RIGHT_FRONT_BOTTOM
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;29; warning; already initialized constant BB_LEFT_BACK_BOTTOM
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;30; warning; already initialized constant BB_RIGHT_BACK_BOTTOM
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;31; warning; already initialized constant BB_LEFT_FRONT_TOP
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;32; warning; already initialized constant BB_RIGHT_FRONT_TOP
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;33; warning; already initialized constant BB_LEFT_BACK_TOP
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;34; warning; already initialized constant BB_RIGHT_BACK_TOP
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;36; warning; already initialized constant BB_CENTER_FRONT_BOTTOM
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;37; warning; already initialized constant BB_CENTER_BACK_BOTTOM
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;38; warning; already initialized constant BB_CENTER_FRONT_TOP
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;39; warning; already initialized constant BB_CENTER_BACK_TOP
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;41; warning; already initialized constant BB_LEFT_CENTER_BOTTOM
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;42; warning; already initialized constant BB_LEFT_CENTER_TOP
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;43; warning; already initialized constant BB_RIGHT_CENTER_BOTTOM
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;44; warning; already initialized constant BB_RIGHT_CENTER_TOP
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;46; warning; already initialized constant BB_LEFT_FRONT_CENTER
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;47; warning; already initialized constant BB_RIGHT_FRONT_CENTER
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;48; warning; already initialized constant BB_LEFT_BACK_CENTER
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;49; warning; already initialized constant BB_RIGHT_BACK_CENTER
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;51; warning; already initialized constant BB_LEFT_CENTER_CENTER
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;52; warning; already initialized constant BB_RIGHT_CENTER_CENTER
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;53; warning; already initialized constant BB_CENTER_FRONT_CENTER
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;54; warning; already initialized constant BB_CENTER_BACK_CENTER
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;55; warning; already initialized constant BB_CENTER_CENTER_TOP
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;56; warning; already initialized constant BB_CENTER_CENTER_BOTTOM
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;58; warning; already initialized constant BB_CENTER_CENTER_CENTER
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;59; warning; already initialized constant BB_CENTER
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;64; warning; already initialized constant MB_ICONHAND
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;65; warning; already initialized constant MB_ICONSTOP
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;66; warning; already initialized constant MB_ICONERROR
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;67; warning; already initialized constant MB_ICONQUESTION
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;68; warning; already initialized constant MB_ICONEXCLAMATION
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;69; warning; already initialized constant MB_ICONWARNING
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;70; warning; already initialized constant MB_ICONASTERISK
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;71; warning; already initialized constant MB_ICONINFORMATION
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;72; warning; already initialized constant MB_ICON_NONE
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;74; warning; already initialized constant MB_DEFBUTTON1
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;75; warning; already initialized constant MB_DEFBUTTON2
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;76; warning; already initialized constant MB_DEFBUTTON3
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;77; warning; already initialized constant MB_DEFBUTTON4
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;82; warning; already initialized constant MESH_SHARP
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;83; warning; already initialized constant MESH_SOFT
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;84; warning; already initialized constant MESH_SMOOTH
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;85; warning; already initialized constant MESH_SOFT_SMOOTH
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;90; warning; already initialized constant POINT_OPEN_SQUARE
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;91; warning; already initialized constant POINT_FILLED_SQUARE
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;92; warning; already initialized constant POINT_CROSS
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;93; warning; already initialized constant POINT_X
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;94; warning; already initialized constant POINT_STAR
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;95; warning; already initialized constant POINT_OPEN_TRIANGLE
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;96; warning; already initialized constant POINT_FILLED_TRIANGLE
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;114; warning; already initialized constant VERSION
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;118; warning; already initialized constant PREF_KEY
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;121; warning; already initialized constant PATH
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;122; warning; already initialized constant PATH_LIBS
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/core.rb;125; warning; already initialized constant PATH_LIBS_CEXT
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/sketchup.rb;21; warning; already initialized constant COLOR_GL_POLYGON
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/sketchup.rb;25; warning; already initialized constant COLOR_ALPHA
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/sketchup.rb;29; warning; already initialized constant RAYTEST_WYSIWYG
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/system.rb;16; warning; already initialized constant PLATFORM_IS_OSX
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/system.rb;19; warning; already initialized constant PLATFORM_IS_WINDOWS
                                    C;/Program Files/Google/Google SketchUp 8/Plugins/TT_Lib2/system.rb;22; warning; already initialized constant TEMP_PATH
                                    I am expecting a Cleanup item in the Plugins menu but do not see it. Let me know if I can help debug! Thanks again.
                                      What version of Linux and Wine are you using?
                                      How did you install the extensions?
                                        saucerful
                                        Thanks for the quick reply! Linux is Debian stable (wheezy) with wine from the repository, version 1.4.1.
                                        Extensions installed via SketchUp GUI.
                                        • tt_suT Offline
                                          tt_su
                                          it would be cool if we could access the delete coplanar feature with respect to the materials via a shortcut πŸ˜ƒ would save me a thousand clicks...
                                          If you set up the dialog to merge only by material you can use the Clean With Last Settings by shortcut. It's a workaround, but it currently works.
                                            saucerful
                                            By the way, I tried installing SketchUp 2013 and got the same output in console and dialog. Let me know if I can help debug. Thanks!
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 48
                                            • 49
                                            • 28 / 49
