    Sketchphysics to shaderlight
    15 Posts 5 Posters 9.9k Views 5 Watching
    • iichiversiiI
      iichiversii
      I did Rich, no luck with it to be honest, but have being getting great results with sketchup, iv a few shorts put together, working on a trailer, im sure you will be impressed with the animations i have created using sketchup once i release the trailer
      Bring on the Rain...
      • iichiversiiI
        iichiversii
        heres a better clip demonstrating sketchphysics rendered in shaderlight http://www.youtube.com/user/J22Fish15?blend=4&ob=5#p/u/21/s4qHkKi0Nyw
          That doesn't look rendered. Looks like native output. Shadows should be softer.
          Best of luck getting ShaderLight to work. I know TwiLight works great with all animation plugins.
          • iichiversiiI
            iichiversii
            Cheers Rich, unfortunately im not going to fork out da yoyos for another rendering engine, hopefully ill get results and ill report it here for future searches
            • numbthumbN
              numbthumb
              @iichiversii said:
              heres a better clip demonstrating sketchphysics rendered in shaderlight http://www.youtube.com/user/J22Fish15?b ... 4qHkKi0Nyw
              It says "Made with Google Sketchup and Sketchyphysics" ๐Ÿ˜•
              I was about to say that Indigo can handle sketchyphysics animations http://www.youtube.com/watch?v=cZ3TKfDPxVw, but since youยดre "not going to fork out da yoyos for another rendering engine"... ๐Ÿ˜„
              Comfortably numb...
              • iichiversiiI
                iichiversii
                lol, cheers numbthumb, but like i said, no more yoyos, lol, ok im trying something different here, if i export the animation to skp files i should be able to render each skp file of the animation, yeah i know it should be time consuming as each skp file has to be rendered seperately, but again i ran into a problem, each skp file looks exactly the same as the first skp file showing no sketchphysics animation, why i dont know, iv posted a new topic on this matter, heres the link http://forums.sketchucation.com/viewtopic.php?f=61&t=41408 if someone can help me out here with this please
                • W
                  wyatt
                  Shaderlight renders scene-based animations only so it won't work with sketchyphysics.
                  • iichiversiiI
                    iichiversii
                    Wyatt i agree with u now after much research, but the skp files exported animation from sketchphysics should work, each file will have to be rendered individually tho, time consuming i know but once finished the render will of captured the sketchphysics animation, in theory it works but my issue now is when i export da animation in skp format the sketchphysics animation does not show
                    • iichiversiiI
                      iichiversii
                      Ok, unfortunately shaderlight doesnt render sketchphysics animations automaticly, but u can export the animations as skp files and manually render each skp file and export as images, i have tested this and it works, but extremely time consuming none the less, im going to contact ArtVPS about this and see if they have any plans to have an automatic update for future version
                      • duanekempD
                        duanekemp
                        What was the final results of these animation tests using Shaderlight?
                        Duane Kemp
                        Kemp Productions
                        Puidoux, Switzerland
                        Gallery:
                        https://duanekemp.artstation.com/
                        • iichiversiiI
                          iichiversii
                          It's been a while since I did this bit from what I remember shaderlight doesn't render a sketchphysics animation, I found you would have to export each frame as a seep rate sketchup file, then render each file, but the draw back was you will need to change each file and start the render manually, this is very time consuming and I gave up then
