    [Plugin] Shellify v1.5 20131217
    14 Posts 6 Posters 7.0k Views 6 Watching
    • KrisidiousK Offline
      Krisidious
      very nice...
      By: Kristoff Rand
      • guanjinG Offline
        guanjin
        Good tool that can remove those lines surface unavailable, retaining only available physical。
        • cottyC Offline
          cotty
          First test looks great, thanks for sharing! (and welcome to the forum!)
          my SketchUp gallery
            rv1974
            after long dull season there's something usefull.
            (and attached within the post 👍 )
            many thanks!
            • Mike LuceyM Offline
              Mike Lucey
              Well done CAUL 👍 I can see quite a few instances where Shellify will be useful.
              Mike
                rv1974
                had some spare time to test it.
                The things I don't like:
                1. it won't work with the complex geometry (see attached pic)
                2. placing the output beside (instead of replacing the preselected)
                  CAUL
                  Thanks for trying out the plugin. If you by complex geometry mean multiple disconnected objects within a group, then no, the script is not made to handle that. If you mean that your geometry is not cleaned in the way you anticipated, then it might be due to the non solid proporties of your object. The plugin tries to maintain a coherent sense of inside/outside and that is only possible if the object is a near solid.
                  @rv1974 said:
                  1. placing the output beside (instead of replacing the preselected)
                  I'm not quite sure what the best way to present the result is, the plugin is by no means unbreakable so I think there is a point to preserve the original as a comparison.
                    Krisidious
                    I've wanted something like this for an entire house model... I model entire interiors, wall thicknesses etc for a house, then I'll want to render it from the outside or I'll want to make lots of copies of the house in a development but the model gets heavy with all the interiors. think it will work? I'm gonna try it...
                    By: Kristoff Rand
                    • guanjinG Offline
                      guanjin
                      Original components, to achieve selective whether to keep?
                        CAUL
                        I don't think the script does what you want. Shellify is basically a cleaning tool to be used after intersections etc. It purges geometry on the inside and flaps on the outside. If you've modeled a house where the wall structure itself is a near solid, then shellify will remove geometry within the wall, but not in the house so to speak.
                          CAUL
                          Ok, I'll add when I got time. In the meantime, 1.3 is altered to replace the original group. If you download this version and want the old behaviour back you can search for
                          replace_original = true
                          in the code, and then change true to false.
                          • guanjinG Offline
                            guanjin
                            CAUL:
                            Thank you, thank you 😍
                              CAUL
                              Bump
