โ ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
Helix problem
It's too small and your path needs to be continuous.
Scale up by 10 and weld the path together. and you'll get this.
no need to weld [although it's better], scale-up does the trick.
Oh,thank you so much !
you may also want to give a look at this http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=51770
