    Cutting a plane
    6 Posts 4 Posters 279 Views 4 Watching
    • hcccsH Offline
      hcccs
      I am trying to trim off the corrugated sheet metal wall of a shack. I put in a plane that divides the two pieces, one of which is to be trimmed off. I have tried to figure out how to do it but failed. I can't use the solid tools because the wall is not a solid, it says.
      http://imagizer.imageshack.us/v2/150x100q90/c/19/adcz.jpg
      How do I do this?
      • KrisidiousK Offline
        Krisidious
        select the geometry and right click... hit intersect selection. Make sure that the object and the cutting plane are in the same group.
        By: Kristoff Rand
        • gillesG Offline
          gilles
          Or, install Zorro2, make a section plane and right click / slice at section: no clean up.
            Krisidious
            ^^Truth^^
            By: Kristoff Rand
            • hcccsH Offline
              hcccs
              Great plugin! Thanks!
              • BoxB Offline
                It is a great plugin, but you can't always use it, so I hope you learnt how to intersect.
