    General question - definition of units (inch/metric)
    15 Posts 6 Posters 1.6k Views 6 Watching
      slbaumgartner
      @artmusicstudio said:
      hi all,
      when the ruby is for all over the world, how can i programm the ruby to know, in which units the user works and makes the input ( = user's skp-preferences-setting)?
      or is it ok fo "force" the user to use metric system (in my case) ?? that would not be user friendly, i think.
      thanx for a tip.
      stan
      I believe you can find these settings in the OptionsProvider named "UnitsOptions" in the model's OptionsManager. The names in that OP are pretty clear, but you may have to do some experimentation to figure out what the numeric values mean for the key "LengthUnit".
      IMHO, forcing metric is entirely between you and your users 😲
      Steve
      • danielbowringD
        danielbowring
        Thomthom wrote a guide for this.
        • tt_suT
          tt_su
          As Daniel mentioned, I wrote an article on this. It's actually less work to make it work for whatever unit the user is using because you use the methods that the Ruby API provides for this.
          Basically, all units in SketchUp is internally inches. Work with that - and just ensure you use the Length.to_s method to present the unit to the user. If you want to define some specific length to your calculations, use the helper methods of the Numeric class, sch as: 1000.mm to define a Length object representing 1000mm. It will be stored as inches, but when you convert it to a string it will appear in the current model's units.
          • tt_suT
            tt_su
            You would rarely need to use those values. Only if you needed to implement a custom unit function that SU doesn't already implement. I did write a library to expand area and volume units - as well as formatting of floats in the user locale: https://github.com/thomthom/SketchUp-Units-and-Locale-Helper
              If your inputbox dialog uses length: 0.0.mm it displays in current units to match the user's settings.
              But if you have it as 0.0 that is a float and it's always interpreted as 'inches' [the 'base-units'].
              If you want to default a value, then you can use a test using the model's OptionsManager.
              If its 0 or 1 it's imperial ["/'] otherwise it's metric [mm/cm/m].
              I'd use something like this pseudo-code:
              if Sketchup.active_model.options["UnitsOptions"]["LengthUnit"] > 1 ### metric
                @length=25.mm unless @length
              else #### imperial 0 or 1
                @length==1.inch unless @length
              That way the user gets a sensible starting default value - otherwise if you set it as always 1" the metric users default looks like 25.4mm !
              Using 25.mm converts properly into other metric values like 2.5cm etc...
              The 'unless' test only sets a default at startup and the last used value is used thereafter during that session [use @@var inside a class & @var inside a module to make it enduring]...
              • artmusicstudioA
                artmusicstudio
                HI AND THANX TO ALL,
                this is going to be a challenge, i will report...
                stan
                • artmusicstudioA
                  artmusicstudio
                  hi,
                  thanx for the tips, i read the articles. i will make changes to my system, so that every saved value will be in inches (like basic skp) and i will recalculate to meters for "metric"-world.
                  but i need a tip for the "inch"-world:
                  do user prefer to input higher values (equivalent > 1,0 m) in feet or inches ?
                  i would like to make my menues
                  metric: meters for concrete etc / mm for steel-details
                  would it be the same for
                  feet / inches ? or shall everything be input in inches? what is common ?
                  thanx
                  stan
                  • jolranJ
                    jolran
                    Normally the user would like to work in current set Units.
                    To convert numbers to that, you could use this for starters ?
                    Someone else may come up with better idea, just a rough idea..
                    edit: ah! I missed Thomthoms SketchUp-Units-and-Locale-Helper
                     #default
                    @su_units = ;inch
                    def set_model_units
                    	current_unit = Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                    	return case current_unit
                    		when 0 then @su_units = ;inch
                    		when 1 then @su_units = ;feet
                    		when 2 then @su_units = ;mm
                    		when 3 then @su_units = ;cm
                    		when 4 then @su_units = ;m
                    # init 1 time in your module
                    set_model_units
                    puts 5.to_l
                    puts (5).send( @su_units )
                      You are [again] over thinking this. πŸ˜’
                      So set your units as say 25.mm if metric, or 1.inch if imperial [testing the model's units - as outlined earlier]... Then there are no odd fractional issues.
                      Then your inputbox dialog will display its values in whatever units settings the user has already for that model.
                      For something longer:
                      18.0"
                      1.5'
                      1' 6"
                      457.2mm
                      ~45.7cm
                      ~0.457m
                      or more logically when it's found as metric make that default
                      450mm or 500mm etc
                      SketchUp has the numeric class addition of 'length', so if the user types in 1" he gets some geometry 1" long, but if he types 25mm although it measures as 25mm it is actually remembered in the SketchUp database in inches - all geometry is remembered in inches, it's displayed in the model-units for the convenience of the user.
                      • tt_suT
                        tt_su
                        You don't really need to recalculate anything. Just keep your units as Length objects and let Length.to_s take care of presenting the unit to the user - as the user prefers it.
                        If you need to specify some fixed values in your calculations, like you want to create a 1x1 meter square, then use the helper methods of the Numeric class:
                        width = 1000.mm height = 1000.mm
                        That will give you Length objects that stored that unit in inches. All done for you by the API.
                        • tt_suT
                          tt_su
                           #default
                          > @su_units = ;inch
                          > def set_model_units
                          > 	end
                          > end
                          > set_model_units
                          > puts 5.to_l
                          That would be the same as:
                          puts 5.to_l puts 5.to_s.to_l
                          There really is few cases when you need to get the model unit and do special work like that. The Ruby API provides most of that - the exception is area and volume, which is why I made that library.
                          If you find yourself poking into the model unit then pause and consider if you are doing too much work. Most of the time when I see this done the API provides a much shorter and easier way.
                          This is something that might need another blog post. It keeps coming up.
                          It's certainly something I want to see improved in the API docs to make it more visible - as these very useful methods are easy to miss.
                          • jolranJ
                            jolran
                            Your right! 😳
                            I wrongly assumed using send instead would be faster, which it isent.
                            • tt_suT
                              tt_su
                              I don't know about the speed differences - but I'd not try to optimize that before it's a problem. Less code = less chance of bugs.
                              • jolranJ
                                jolran
                                Heh, it was like this for 100 puts statements in the console.
                                to_s_to_l: 2.884
                                using send: 2.915
                                Rookie premature refactoring gone bad πŸ˜„
