    Simple Extension for Mac
    25 Posts 6 Posters 2.7k Views 6 Watching
    • Al HartA
      Al Hart
      @thomthom said:
      404 — Bitbucket
      (bitbucket.org)
      Thanks, ThomThom, that looks like what I am looking for.
      I see you had posted it before, but I didn't know what it was at the time.
      Al Hart
      IRender nXt from Render Plus
        Mind you, I recently found http://rubyinstaller.org/downloads/ which I think is a better choice for Windows than the Visual Studio solution I'd used.
        • O
          olilej
          I've been playing around with C Extension recently and I would like to know how if there is an equivalent of is_a? ruby function in C level.
          I found rb_obj_is_instance_of but it seems to be only meant for native ruby types.
          • Al HartA
            Al Hart
            [Ignore this for a minute - I need to add a second parameter for what the value to pass to is_a?]
            You can execute the equivalent of any ruby function using rb_intern() and rb_funcall()
            Try this:
            VALUE fid = rb_intern("is_a?");
            VALUE vret = rb_funcall(klass, fid, 0);
            Al Hart
            • Al HartA
              Al Hart
              Here is a better example, equivalent to
              Sketchup.is_a?(Module)
              VALUE Sketchup = rb_path2class("Sketchup");
              VALUE Module= rb_intern("Module");
              VALUE is_a = rb_intern("is_a?");
              VALUE result = rb_funcall(Sketchup, is_a, Module, 0);
              Al Hart
              • Dan RathbunD
                Dan Rathbun
                If you have the CHM... you can click on the method description, and the C source will popup:
                (Also works for online version, but the source link must be clicked directly, and is only visible when the mouse is hovering over the method description.)
                I'm not here much anymore.
                • Dan RathbunD
                  Dan Rathbun
                  So it looks like there are some macros defined in C, to make life easier ... CLASS_OF(), RCLASS_SUPER(), etc.
                  • Dan RathbunD
                    Dan Rathbun
                    • Pragmatic Programmer: Extending Ruby 1.9
                    • O
                      olilej
                      Great, my goal is to make sure I'm dealing with a Entity in order to access its attributes.
                      Here is the code I've come up with.
                      VALUE result = rb_obj_is_kind_of(obj, rb_path2class("Sketchup;;Entity"));
                      if (Qtrue == result){
                      	VALUE rval = rb_funcall(obj, rb_intern("get_attribute"), 2, rb_str_new2("dynamic_attributes"), rb_str_new2("..."));
                      • Dan RathbunD
                        Dan Rathbun
                        Only Sketchup::ComponentDefinition and Sketchup::ComponentInstance will have dictionaries with that special name.
                        • 2 / 2
