    Simple Extension for Mac
    25 Posts 6 Posters 2.7k Views 6 Watching
    • Al HartA
      Al Hart
      We had about the same experience as ThomThom.
      Calling ruby functions from C-code was slower than calling them from ruby directly in SketchUp.
      e.g. The C-code replacement for:
      value = model.get_attribute “dictionaryname”, key, defaultvalue)
      can be done directly, (actually rather indirectly), from C-code, but the execution time is slower than in SketchUp ruby.
      But other things, such as maintaining a table for vertices, and then doing special processing for vertices was faster.
      Also, we were able to use Windows dialogs, functions in other Windows DLLS, etc. and attach them to SketchUp.
      Also, we were able to use all the Ruby stuff from C++ because ruby\1.8\i386-mswin32\ruby.h, (part of the ruby code), includes
      #if defined(__cplusplus)
      extern "C" {
      #endif
      Back to the original question.
      Has anyone interfaced to C routines from the Mac, and if so could you share a sample of some sort to get us started...
      Al Hart
      IRender nXt from Render Plus
        404 — Bitbucket
        (bitbucket.org)
        • Al HartA
          Al Hart
          @thomthom said:
          404 — Bitbucket
          (bitbucket.org)
          Thanks, ThomThom, that looks like what I am looking for.
          I see you had posted it before, but I didn't know what it was at the time.
          Al Hart
            Mind you, I recently found http://rubyinstaller.org/downloads/ which I think is a better choice for Windows than the Visual Studio solution I'd used.
            • O
              olilej
              I've been playing around with C Extension recently and I would like to know how if there is an equivalent of is_a? ruby function in C level.
              I found rb_obj_is_instance_of but it seems to be only meant for native ruby types.
              • Al HartA
                Al Hart
                [Ignore this for a minute - I need to add a second parameter for what the value to pass to is_a?]
                You can execute the equivalent of any ruby function using rb_intern() and rb_funcall()
                Try this:
                VALUE fid = rb_intern("is_a?");
                VALUE vret = rb_funcall(klass, fid, 0);
                Al Hart
                • Al HartA
                  Al Hart
                  Here is a better example, equivalent to
                  Sketchup.is_a?(Module)
                  VALUE Sketchup = rb_path2class("Sketchup");
                  VALUE Module= rb_intern("Module");
                  VALUE is_a = rb_intern("is_a?");
                  VALUE result = rb_funcall(Sketchup, is_a, Module, 0);
                  Al Hart
                  • Dan RathbunD
                    Dan Rathbun
                    If you have the CHM... you can click on the method description, and the C source will popup:
                    (Also works for online version, but the source link must be clicked directly, and is only visible when the mouse is hovering over the method description.)
                    I'm not here much anymore.
                    • Dan RathbunD
                      Dan Rathbun
                      So it looks like there are some macros defined in C, to make life easier ... CLASS_OF(), RCLASS_SUPER(), etc.
                      • Dan RathbunD
                        Dan Rathbun
                        • Pragmatic Programmer: Extending Ruby 1.9
                        • O
                          olilej
                          Great, my goal is to make sure I'm dealing with a Entity in order to access its attributes.
                          Here is the code I've come up with.
                          VALUE result = rb_obj_is_kind_of(obj, rb_path2class("Sketchup;;Entity"));
                          if (Qtrue == result){
                          	VALUE rval = rb_funcall(obj, rb_intern("get_attribute"), 2, rb_str_new2("dynamic_attributes"), rb_str_new2("..."));
                          • Dan RathbunD
                            Dan Rathbun
                            Only Sketchup::ComponentDefinition and Sketchup::ComponentInstance will have dictionaries with that special name.
                            • 2 / 2
