    Suppressor Thread
    14 Posts 6 Posters 500 Views 6 Watching
      Coach_Travis
      I am working on a new project and caught a snag. I am trying to add threading to my M4 barrel and can not seem to get the hang of it. On the picture below I would like to add exterior threading to the part that is yellow. Does anyone know a good tutorial to assist me with this?
        Have you searched the forum for 'threads'? I expect you'll find three or four different approaches. Due to the small size you'll want to model them at a larger scale and scale down afterward.
          Coach_Travis
          Dave - Thanks for the heads up about the search. I have used it in other forums and it didn't come to mind in this one. Unfortunately, I must start over because I was using radius instead of diameter for my measurements. DOH!
          • cottyC Offline
            cotty
            You know the scale tool? You can scale a 3D object along 2 axes...
            my SketchUp gallery
              Coach_Travis
              Yeah, I had some other errors so I decided to start over.
                TECHDAVE02
                here is a couple techniques
                http://www.youtube.com/watch?v=IT5r3AQZBnw
                http://www.youtube.com/watch?v=MKrWDNDd62c
                  Coach_Travis
                  Thank you for the videos. I actually used the "screw 1_5" plugin. It worked very well.
                    CL
                    I may be wrong, but it looks like you have the faces reversed. The grayblue ones should be on the inside.
                      Coach_Travis
                      Yeah, good catch. That is how the plugin makes it. I caught it right after I submitted it.
                        Coach_Travis
                        I think I got the hang of it. What do you think?
                        • Rafferty94R Offline
                          Rafferty94
                          Looks pretty good.
                          If you are going for close up detail from what the picture shows it is just faces made onto the cylinder? ( ❓ ) that could bring your model down when it comes to render.
                          Try playing around with different types like this...
                          http://physicsgeek.mu.nu/archives/screw-thread.gif
                          Notice how the one raised thread is continuous from top to bottom.
                          Scott.
                            Coach_Travis
                            Raff - I do not exactly know what you are referring to. The threading was not created on the face. It was made using a plugin. Here are two pictures of them close up. The first one is external threading, and the second is the internal threading.
                              Rafferty94
                              Ahh...
                              Forgive me, I could not make out the detail from the attachment above my post.
                              Scott.
                                Coach_Travis
                                @rafferty94 said:
                                Ahh...
                                Scott.
                                Not a problem. Thanks for looking out.
