    Video Card Question
    48 Posts 8 Posters 4.4k Views 8 Watching
    • Joe WoodJ
      Joe Wood
      no I haven't Glen, I'd need to remove it to see the sticker on the bottom. Too many connected wires has me intimidated!
      I did google some numbers on the side of the psu
      cn 0f0340-47890-353-2067
      and found this
      http://www.memory4less.com/m4l_itemdetail.aspx?itemid=1442482616&partno=0F0340&rid=88&gclid=CJWs-YDGzroCFUlyQgod8FQAIw
      Joe Wood
      woodsshop.com/
      • Joe WoodJ
        Joe Wood
        I asked this video card question at the Dell forum, and someone suggested this
        "Money would be better spent finding a GX620 with Pentium D.
        The 4600 is DDR with AGP.
        The GX620 uses DDR2 and has PCI-E video and with Pentium D would be many times faster in all aspects and would have many video options that could be re used later in a newer better faster machine."
        ERROR: The request could not be satisfied
        (www.amazon.com)
        what am I looking at on that page? Isn't that tower the whole computer? For $83? That's right around what I was thinking of paying for the video card alone.
        Joe Wood
        woodsshop.com/
        • G
          Glenn at home
          You know Joe, getting a newer, used PC is not a bad idea. Here is a local CL add in your area that has 2 of those for $90 each.
          http://sandiego.craigslist.org/csd/sys/4170748294.html
          They are older but they do use PCIe video cards (the newer ones) and they are dual core, 64-bit cpus which will be far and away better than your P4 based system. I really would not spend any money on that old system. I had one just like it and while it was a good PC for the 6 years I had it just got to a point where it was not worth upgrading it.
          Search around a bit on CL and fins one local, this way you can maybe see it run and check it's condition before you buy.
          Good luck πŸ˜„
          • Joe WoodJ
            Joe Wood
            Boy I don't know, then I'd have to transfer everything on this computer over onto the newer one and I've never done anything like that before. Is it that difficult?
            Joe Wood
            woodsshop.com/
            • G
              Glenn at home
              Yeah you'd basically have to reinstall all applications and then transfer all files as well. That is the worst part of getting a new PC. It can be a pain but it's worth it when you get better hardware.
              • sketch3d.deS
                sketch3d.de
                because of this investing in a new, capable PC which will last some time is probably a better choice then investing in some ol' stuff... desktops are cheap these times, this one w/ the GTX from above and SU will fly.
                Norbert
                • soloS
                  Actually setting up a new machine is therapeutic, especially if you get one with a larger HDD or multiple HDD's, you get a clean fast uncluttered machine to start with, you can organize the install as you please, put stuff in the right places, only load what you need resulting in a slick fast 3D machine.
                  • G
                    Glenn at home
                    Good point from both Solo and Norbert.
                    • Joe WoodJ
                      Joe Wood
                      Well folks, I don't really need a fast slick computer, this one is doing just fine (especially after flashing the Bios whatever that means), except for the video card and even that is slowing my SUp only a little bit. I hardly ever do large complex models. Besides I want to get a laptop here pretty soon.
                      so, I'm a little confused about which card to get, could I get a link to a card I can just order?
                      Joe Wood
                      woodsshop.com/
                      • sketch3d.deS
                        sketch3d.de
                        @joe wood said:
                        ...except for the video card and even that is slowing my SUp only a little bit...
                        the CPU is the crucial issue for speed in SU. The video system needs to provide reliable OpenGL support first, which automatically means a dedicated and therefore capable video card to some extent.
                        The best/fastest/latest GeForce for ol' systems w/ AGP slot is the 7800 series. You can buy a new (expensive) GF 7800 GS at Amazon... or do a fall back to the cheaper and less power consumpting GF 7600 GS.
                        Good Luck again,
                        Norbert
                        • 3 / 3
