    Cutlist 4.1.5 doesn't work
    2 Posts 2 Posters 345 Views 2 Watching
    • zain01Z
      zain01
      Hi There,can anyone tell me why i can't get cultist to work anymore?It was working and then decided to stop.I have downloaded it again and selected some geometry,the cultist window appears but when i press the Run button nothing happens.I don't think it is a trial version.I desperately need a cultist plugin that supports metric.
      Thanks in advance. Z
        I don't know exactly what the problem is but a couple of things come to mind. The first one is that the Permissions for the Plugins folder aren't set to Read and Write. Another is that you've got some plugin that is conflicting with CutList.
        Make sure you have some value in the box for saw kerf size.
        Why are you still running 4.1.5? We're up to 4.1.8 now.
        If you switch versions make sure you delete the older version and its folder first.
