    Text Placement & Editing in Sketchup
    6 Posts 2 Posters 650 Views 2 Watching
      Battlecat
      Hello:
      I am looking for a way to edit text, either flat or 3D, once it has been placed into the document. It seems illogical to have to delete and replace the text in its entirety each time I need to make a change.
      My current work around to getting clear text has been to import a graphic place holder.
      My situation is that I am re-creating a room from a museum. In this room there are around 20 wall plaques with flat text on them. I need to be able to place flat text on them or 3D text that is very minimally extruded so that when a user looks at the room they can read the text virtually on the plaque from the front not the sides.
      This model is intended to be a demo of our proposed room layout in a real museum.
      Any help or pointers would be appreciated.
      thank you,
      BC
        Illogcal or not, if you are making 3D Text, once it is placed, the only editing options are those that would apply to any other component made or edges and faces.
        You could use Thomthom's Editable 3D Text plugin, though. It will allow you to create and edit 3D text even after you've placed it.
          Battlecat
          Hello:
          Thank you for your reply. πŸ˜„
          I have looked up the user Thomthom and found his page of extentions. Here is the URL I found: http://extensions.sketchup.com/en/user/261/store
          I do not see anything that relates to editing text once it has been placed into a model. Am I overlooking it?
          As a side note I did not specify but I am using the free version of 2013. I do not know if that matters.
          Thank you again,
          BC
            Try this: http://sketchucation.com/forums/viewtopic.php?p=457802%23p457802
              Battlecat
              Thank you.
              I will have to try this when I get home. The reason being is that apparently little did I know I will need administrator rights to install an extension for Sketchup.
              I will get back to you on how it works this evening.
              thank you,
              BC
                Are you really running SketchUp under Linux?
                On Windows and Macs, anyway, you need to have full permissions established for the Plugins folder. You need to be able to install files and in the case of many plugins, they need to have the ability to write to files in the Plugins folder to make the changes you do work.
