    [Plugin] Center on Origin UPDATE May 23, 2013
    35 Posts 18 Posters 45.4k Views 18 Watching
    • Chris FullmerC Offline
      Oh that's not good 😞
      I'll have to work on testing this one tomorrow. I'm not sure what has gone wrong, but I'm pretty sure it'll be easy enough to find. Thanks Charly,
      • charly2008C Offline
        charly2008
        No reason, I have to thank you. Another note, in Sketchup 2013 it works fine.
          Do you have any of my other scripts installed in 2013?
          Also make sure that you deleted the old version that is in SU 8.
            charly2008
            I have to correct myself, even in "Sketchup 2013," an error message appears.
            Yes I have more plugins from you, see picture below.
              Hey Charly, the screen shots are useful, but it does not show clf_center_on_orogin.rb listed in the lower screenshot, which I would expect, since you have the folder loaded, and the errors seems to be pertaining to center on origin.
              I wonder if you have plugins lost in the Compatibility folders sonwhere. In the plugins folder, at the top do you see "Compatibility Folders" anywhere? See the first screenshot in the following:
              Vista's "Show Compatibility Files" and the Scrumptious Wonder that is File Virtualization
              I was trying to convert some (totally legal) video files into MP4 format for ...
              (www.hanselman.com)
              If you have that, click on it, select everything there and MOVE it back into the actual plugins folder.
              Then try to restart SU, if you still have issues, take screenshots again and let me see what you have.
              Or if you don't have any compatibility folders, could you send me your copy of center on origin? Thanks,
                charly2008
                I have all the clf_plugins piece by piece deactivated and found out that the "clf_arc_centerpoint_finder.rb" caused the error. After reinstalling everything works perfectly again. Sorry.
                Charly
                  Oh good, glad you got it working. That makes sense to me. I had accidentally released a bugged version of arc_centerpoint_finder that was live for a few days. Looks like you got a copy of that one - sorry!
                    charly2008
                    Dear Chris,
                    I have now found that you are represented in the "Plugins menu" three times. Is that intentional from you?
                      Hi Charly, that is an unfortunate side-effect of my efforts to clean up my scripts. In your case, from what I can see, anything in the first and third menus are old scripts and should be updated. Unfortunately the updated versions are not yet published anywhere.....so for now you're stuck with the extra menu items - sorry about that! I'll let you know when I get all my updated scripts published. Thanks!
                      • N Offline
                        nesh70
                        Hi!
                        Thanks for creating so useful SU plugin!
                        BTW, is there a way to center a model or component like the image B (not like the original script do - image A)?
                        Best regards!
                        Original plugin behavior.
                        My intention.
                        • N Offline
                          nesh70
                          @nesh70 said:
                          Hi!
                          Best regards!
                          I found out how to achieve it, changing the line
                          vector = point.vector_to [0,0,0]
                          to
                          vector = point.vector_to [0,0,model.bounds.height / 2]
                          • TIGT Online
                            Why not use something like
                            vector = point.vector_to(model.bounds.center)
                            for the center, or
                            pt=model.bounds.center pt.z=model.bounds.min.z vector = point.vector_to(pt)
                            for the center-bottom
                              babak
                              @nesh70 said:
                              @nesh70 said:
                              Hi!
                              I use this plugin for centering an object while setting it's bounding box bottom at 0 :
                              center_group_bottom.rb
                              You can find it at http://www.fsdeveloper.com/forum/showthread.php?t=71321
                              download link
                              http://www.fsdeveloper.com/forum/attachment.php?attachmentid=10061&d=1310763814
                              • N Offline
                                nesh70
                                @babak said:
                                @nesh70 said:
                                @nesh70 said:
                                Hi!
                                download link
                                Thanks babak! It works perfectly! Just what I wanted!
                                  tsurfing
                                  Hi Chris,
                                  Tried to enter the patch script at the start of this thread, but the the ruby script is different than what you quoted:
                                  And here's another option. If you want it to reset the component rotation and scale, edit the ruby file in a plain text editor (like Notepad for example) and after the line:
                                  if comp.typename == "Group" || comp.typename == "ComponentInstance"
                                  add the two following lines:
                                  t = Geom::Transformation.new comp.transformation = t
                                  This is it now:
                                  sela.each do |e| if e.is_a?(Sketchup::Group) || e.is_a?(Sketchup::ComponentInstance) to_move << e end
                                  I need to zero out the components rotation/scale
                                  What's your thoughts?
                                  Terry
                                  • 2 / 2
