    SketchUp and OSX Mavericks....
    83 Posts 22 Posters 17.9k Views 22 Watching
    • E
      ericschimel
      Mine's enabled as well... It always has been....
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
      • mariochaM
        mariocha
        Here, LightUp (pre-last update), just opened the preferences pane blank, no message.
        and
        Keyframe Animation cannot run saying Java Script needs to be enabled, but it is.
        Adam, any clue on this JS bug ?
        %(#008000)[Mario C.
        • Chris FullmerC
          RE: the test file used here - we found that the test file has a typo in it, and that is why the remote download is failing in that script. It actually is trying to reach an invalid URL πŸ˜„ 😒
          So unfortunately that isn't showing any errors once the typo is corrected.
          We're still looking into this.
          • H
            honkinberry
            I can give you a quick example to one that isn't working if you need.
            --J
              driven
              @mariocha said:
              ... cannot run saying Java Script needs to be enabled, but it is.
              Being enabled in Safari, will not effect WebDialogs, which have JS enabled by default...
              you can check what works in SU with something like this pasted into Ruby Console
               wwhdlg = UI;;WebDialog.new("wot_works_here", true, "wwh", 739, 641, 50, 50, true);
               wwhdlg.set_url "http://dante.dojotoolkit.org/hasjs/tests/runTests.html"
               wwhdlg.show_modal
                @Chris
                Do you refer to Eric's post that modified some test rb/html I set up - using href=... ?
                I find that it works fine in both .local and .remote versions on all OSs... except with MAC-Mavericks with just .remote...
                If you explain the typo we could look at it [help us to help you...] BUT... it only fails for me on MAC-Mavericks using a .remote html - so IF it has a typo why would it work OK in the other OSs ??? πŸ˜’
                  driven
                  works on mavericks with 'dropboxusercontent vs. dropboxusercontext'
                    Yes πŸ˜’ I now have the typo - passed from another source...
                    That must be Eric’s Web-guy’s typo... he added that 'remote' code to an earlier test setup I wrote... however, it still works fine on all OSs [except Mavericks] with AND without that typo ???
                    I confirm that the corrected 'allow_actions_from_host' code does now work on Mavericks as well as all other OSs... most puzzling...
                    BUT this begs the questions... as to why very similar code fails in the SketchThis toolset, when its 'allow_actions_from_host' IS identical to the url that its ruby specifies...
                    • Chris FullmerC
                      Thanks John - I think that is the typo in question.
                      As to why it works in all other OS's except for Mavericks.....that I don't know.
                      • Chris FullmerC
                        Oh, TIG already responded. Yes, this is an odd one.
                        • W
                          Warped9
                          I started this discussion so I might as well put in my two cents. My experience with Mavericks so far has been generally positive. In regard to SketchUp I installed Make while keeping SU8 on hand for now. SU8 doesn't seem to run any different for me (as far as I can tell) on Mavericks than it did with Mountain Lion. However, Make does seem to run somewhat better (as far as I can tell) with Mavericks than SU8 does with Mountain Lion.
                          One odd thing, though. My SketchUcation Store plugin doesn't connect anymore in SU8. I just get a message saying V2 is available, but when I try to click for the update I just get an error message. I can still install extensions the old way by downloading them manually and using the Extensions Manager found in SU Preferences. I've even tried installing the V2 of SketchUcation Store through the Extensions Manager and I still get the error message afterwards when I try to use the plugin. The SketchUcation Store plugin works fine in Make.
                            slbaumgartner
                            Chris,
                            It is easy to scan the WebDialog framework and confirm that this error message emerges from it, not from a Mavericks system library or framework. But without reverse engineering the WebDialog code (which for ethical reasons I won't attempt), it is impossible for us outsiders to know what WebDialog is trying to do when it throws this error. I have built and think that I understand the sample custom protocol handler that Apple provides, but it does not trap any issues with the URL. Without disclosing some proprietary info, would it be possible for the Trimble engineers to tell us what logic test fails when WebDialog throws this error? That info would help to track down what about Mavericks and certain URLs is peculiar to the problem.
                            As a different matter, it seems like this topic has gotten quite technical - maybe it should be moved or restarted in the Developers forum?
                            Steve
                            • Chris FullmerC
                              Yeah, the developer's forum is a good place for it I think.
                              Still looking into it on our end, nothing new to add to the discussion yet.
                                It's already in the Devs' forum πŸ˜‰
                                • Chris FullmerC
                                  I just had my mind blown β˜€
                                    slbaumgartner
                                    For what it's worth, I just noticed that the same typo was present in both the TIG.remote and TIG.local methods, but only the TIG.remote failed due to the typo. Does allow_actions_from_host() look at previously loaded pages to see whether that host is used by any of them? How does the SketchThis ruby obtain the host URL it passes to this method?
                                      slbaumgartner
                                      faster than a speeding bullet...
                                        And of course the local version didn't need the' allow' anyway - it was a web-guy/Eric tinkering with my original ruby πŸ˜’
                                        Correcting the typo in the remote version does not change things anyway - the remote still fails with Mavericks... but the local version succeeds [with the unnecessary 'allow' method removed, on with the typo corrected or the typo intact]
                                        BUT the weird thing is that if you try the [corrected OR typo-ed] tests on a pre-Maverick MAC or a PC, then both the local and remote versions perform just fine, as if the 'allow' and/or typo is ignored and the 'allow' is 'an irrelevance' πŸ˜’
                                        • H
                                          honkinberry
                                          Actually, it does just seem to be exactly that, allow_actions_from_host.
                                          I had noticed with V6 that it was ignored, so I never implemented it.
                                          But in my remote WebDialog, which is failing, I simply add an allow_actions_from_host, and suddenly now it's working again.
                                          --J
                                          • Chris FullmerC
                                            I'll jump in now, I concur that it all appears to be related to the dlg.allow_actions_from_host method. I think its possible that Win and OS have not actually been honoring that method. But Mavericks now suddenly does.
                                            So if people are not using it, it will dis-allow certain actions with remote websites and throw that error.
                                            If you do use it (which you really should now), make sure you have the syntax correct. You should be giving it a domain, not a url. example: dlg.allow_actions_from_host("http://www.sketchup.com") is not correct, it should be dlg.allow_actions_from_host"www.sketchup.com"
                                            Now I'm curious to know if that is enough to fix all/any of the problems, or are people still seeing other problems?
                                            • 3 / 5
