    [New!] Paradise Sandbox 1.1 is out!
    extensions
    30 Posts 4 Posters 5.5k Views 4 Watching
      Cool πŸ˜„
      Zoom all when you are losted over or under in the big ocean? πŸ˜„
      Does the prog run under Vista without problem ?
      Does the free version can import (dae) in an empty scene ?
      Seems the Import section window don't work! 😲
      (can we import dae file by menu and not by drag and drop on this window asset who seems no responsive )
        ParadiseSandbox
        Let's see:
        Yeah, it should.
        Yes. In fact it's not needed to have an scene/project opened. You can import assets just by drag&drop them to the window.
        That's not normal. Are you sure you're running "Paradise Sandbox.exe" with administrator privilegies? (Right mouse click -> Run as administrator).
        Otherwise Paradise Sandbox will fail when writing/updating files since the v1.0.0 installator doesn't set up properly the writing permissions :/. The 1.0.1 version will fix that but until the moment the "administrator hack" is needed.
        If you're running it as administrator, then please post at Paradise forums: http://paradise-sandbox.com/forums/ with more deatils about when it becomes unresponsive (if before or after clicking on the 'Import' button, etc) and eventually the .dae you're using in order to recreate the issue here and fix it!
        Cheers,
        Xavier
          ParadiseSandbox
          Version 1.0.1 just released! That should fix all the problems πŸ‘
            ParadiseSandbox
            Here is an step-by-step tutorial showing how to import assets from SketchUp to Paradise Sandbox:
              ParadiseSandbox
              Here is a little example of the new "billboard-based flares" support for lights, which has been added in 1.0.2 (coming next week):
              http://paradise-sandbox.com/media/Ship_Sketch.png
              Scene build time: 10 min (mostly due to manually placing lights)
              Render time: real-time, 30fps
                ParadiseSandbox
                Paradise Sandbox 1.0.2 has been released!
                Changelog:
                • [Improvement] Splash-screen: new information messages have been added and the update frequency has been increased (less chances of becoming unresponsive due to large loading times). If thumbnails are not up to date the splash screen will show detailed information about the thumbs generation process
                • [New] New hotkey: Ctrl+S for saving current project changes
                • [Improvement] Network system: better error handling when server replies are mal-formed
                • [Improvement] 'License.txt' files placed in different folders are excluded from the resource manager. No more warnings about duplicated 'License.txt' resources.
                • [Fix] Moon halo not being affected by HW gamma correction.
                • [New] Billboard-based flares for point-lights.
                • [Improvement] Lights don't have anymore two colors (diffuse & specular). Only one, which is physically correct and simplier.
                • [New] "Ferry on the night" sample scene added to 'Sample proyect'. Showcasing billboard-based flares for point lights
                • [Fix] In Windows Vista and 7, if while a scene was running (viewport with 3d content) the user wanted to open a another project (File->Open) it freezes.
                • [New] Render system is now automatically selected based on current hardware by default (PEngine.ini). No more asks during the installation process about the graphics card vendor.
                • [Improvement] The 'Debug' property in the shadows setion of scenes has been removed (it didn't have any effect on release buils).
                  Download at http://paradise-sandbox.com/
                  ParadiseSandbox
                  Paradise Sandbox 1.1 development is coming along nicely, here is a sneak peek:
                  http://paradise-sandbox.com/media/LensFlare1_1.png
                  Paradise Sandbox 1.1 will be release along the last week of November, some of the new features are listed below:
                  1. Improved lens-flare effects (see above image!)
                  2. Camera orbiting behaviour: http://www.youtube.com/watch?v=OUS-Fjo9XZg
                  3. Improvements to the high-quality interactive renderer. Photo-camera mode.
                    This is the last month for taking advantage of the 40% discount offer!
                  More info at: http://paradise-sandbox.com/
                  Xavier
                    ParadiseSandbox
                    Video: 1280p, real-time. New lens-flare effect.
                      Over the rain-bow! β˜€
                        ParadiseSandbox
                        πŸ˜„
                        Yeah, the chromatic distortion is quite noticeable, but it looks really cool!
                        And yes, some cameras (depending of the number of lenses and distances between them) produce these rainbow patterns in the "real life" πŸ˜„
                          ParadiseSandbox
                          A little but nice view using the new HDR system:
                          http://img69.imageshack.us/img69/2259/71gt.png
                            ParadiseSandbox
                            Fog support coming soon in v1.1:
                            http://img708.imageshack.us/img708/7522/fvj4.png
                            http://img853.imageshack.us/img853/4573/wzx7.png
                              ParadiseSandbox
                              The classical Vacation House rendered in Paradise Sandbox.
                              Original:
                              http://img440.imageshack.us/img440/2010/d3c.png
                              Paradise Sandbox real-time render:
                              http://img89.imageshack.us/img89/6806/gd5f.png
                                ParadiseSandbox
                                New features:
                                • New lens-flare system
                                • Fog support
                                • Photo-camera behaviour has been added in the high-quality renderer. Press 'C' to save a capture! (Captures are saved in APP_FOLDER/Captures)
                                • Camera orbiting behaviour has been added. Hold the middle mouse button while moving the mouse.
                                http://img4.imageshack.us/img4/1520/6vqc.png
                                Full changelog:
                                • [New] NVIDIA drivers are asked to use the high-performance graphics unit if possible
                                • [Improvement] The code related to objetcts picking management has been refactored and now is faster, more efficient and also always select the right face.
                                • [New] Camera orbit behaviour added. Use the central mouse button in order to orbit around the scene. https://www.youtube.com/watch?v=OUS-Fjo9XZg
                                • [New/Improvement] Improved lens-flare system
                                • [Improvement] No more waits due to external resource changes when removing a scene.
                                • [Fix] Important bug-fix related to multi-monitors on non-Nvidia systems.
                                • [New] Fogsupport
                                • [Improvement] Some unused oceanproperties has been removed
                                • [Fix] Ocean will now work without the foam component
                                • [New] Photo-camera mode in high-quality renderer
                                New documentation available:
                                • Sky system: http://paradise-sandbox.com/docs/Sky_and_ocean/Sky
                                • Ocean system: http://paradise-sandbox.com/docs/Sky_and_ocean/Ocean
                                • Fog: http://paradise-sandbox.com/docs/Effects/Fog
                                Download now! http://paradise-sandbox.com/#download.php
                                  ParadiseSandbox
                                  Hello community!
                                  This is last week for purchasing Paradise Sandbox PRO with a 40% discount.
                                  At the end of the post you can see a funny image from the very last feature: billboards, coming soon along December in v1.2, this new version will also include support for spotlights with shadow support and penumbra estimation.
                                  Versions 1.3 and 1.4 will be really interesting due to the integration of an advanced animation system: animate cameras, objects, effects... and generating high-quality videos from these animations is going to be possible thanks to this upcoming animation system!
                                  Stay tuned.
                                  http://img824.imageshack.us/img824/2791/gu5g.png
                                    Refreshing! β˜€
                                      ParadiseSandbox
                                      Here is a sneak peak image from the Christmas scene that we're preparing at Paradise Sandbox (will come with a detailed breakdown/tutorial) πŸŽ‰
                                      http://img837.imageshack.us/img837/5286/nmax.png
                                      @Pilou
                                      Still refreshing? πŸ˜‰
                                      Xavier
                                        dmatho
                                        depending on the hemisphere, since I'm up North (in Cambridge, MA, USA) I'd have to say "heartwarming" πŸ˜‰
                                        Cheers,
                                        . Diego .
                                          Now it's very hot! πŸ˜„
                                            ParadiseSandbox
                                            @dmatho said:
                                            Yeah. I'm in Madrid (Spain), so we're more or less at the same latitude, and I wish having a fireplace like this in my house for these months πŸ˜„
                                            Maybe I will do a summer scene for next year's Christmas scene (Santa with a swimsuit? Oh, that could be dangerous!), we have to make South hemisphere customers be happy too πŸ˜›
                                            Hehe πŸ˜„. It was the perfect ocasion to me for creating an entire interior scene. I've already improved a lot the workflow for placing little objects and little lights (the Christmas tree is starting to look really cool!). I am tempted of showing new images, but I will wait until Christmas! πŸ˜›
                                            It's a shame not being a 3D modeler (or doesn't having the time for properly doing it) and be using only objects from the SketchUp Warehouse (on the other side that's good since it will prove that engineered models are not required to create a nice scene in Paradise!).
                                            The breakdown will be a very interesting read for a lot of people from this community, and especially for Paradise users, since it will show some tricks that can be used for any kind of real-time rendering project.
                                            Cheers,
                                            Xavier
