    Syd Mead's VEX (model progression)
    75 Posts 12 Posters 10.4k Views 12 Watching
    • Bryan KB Offline
      My next project. Syd Mead's VEX.
      This and one other drawing are all I have to go on. There will be much, er, artistic license. πŸ˜‰
      The only really hard part I see will be the wheels, which look like early versions of complex spring wheels and some kind of interior cockpit.
      If anyone has better reference pics, please share them if you can.
      • soloS Offline
        Go for it, good luck and remember we gonna render the hell out of it in the end. πŸ’š
          Men on Mars, Moon, ... πŸ˜„
          • hellnbakH Offline
            hellnbak
            You have this one?
            • tademaT Offline
              tadema
              Here's one.
              • Bryan KB Offline
                Thanks hellnback. That will be a big help with the wheels.
                Thanks John, but that is a different vehicle.
                • Bryan KB Offline
                  Syd. I can only wish I can do half his work. πŸ€“
                  • hellnbakH Offline
                    hellnbak
                    A slightly larger shot, might show some more detail.
                    As far as the wheels tho, the source (http://forums.cgsociety.org/archive/index.php/t-896887.html) states
                    "*This is a continuation of the VEX concept illustrated by Syd Mead. It is a long-term mobile living space for astronauts and allows for continuous exploration far from the landing zone.
                    I had the wheel design floating around as a personal project for a long time, and after I learned about this contest, I discovered that Syd created a concept drawing that had almost the exact same wheel structure. I decided that I had to move with this coincidence and pay homage to the original*."
                    So the wheels might differ from Syd's original, just a heads up.
                    • Bryan KB Offline
                      Thanks again, hellnback.
                      The wheels look close enough and as I only have 2 pictures for reference and neither have very close detail of the wheel structures, what I model will have to do.
                      But it's all for fun, so hey, why not? πŸ˜„
                      • soloS Offline
                        Still struggling with the wheels.
                        πŸ˜„
                        You can do it, even if you have to make it up as you go.
                        You only have to make one. πŸ’š
                        • Bryan KB Offline
                          Still struggling with the wheels. Just not enough detail in the reference pictures. I really just need to make a design decision and then go with it.
                          The rest looks easy enough to do.
                          • Bryan KB Offline
                            πŸ˜„
                            This is true. πŸ˜„
                            • iichiversiiI Offline
                              iichiversii
                              Thats funny, i only watched "Last day on mars" last nite and there was a rover the astronauts used to get around the surface that i was planning on modelling which is very similar to this rover, you can find details about the movie here but i will say its not a great movie but the near future tech is cool http://www.imdb.com/title/tt1709143/
                              Now you got me started, lol
                              Bring on the Rain...
                              • Bryan KB Offline
                                Test and hold until tomorrow.
                                • Bryan KB Offline
                                  Not much to look at right now. Just trying to get the overall outline shape and scale of the wheels.
                                  Created as component and then duplicated and mirrored. That's the middle line down the middle.
                                  • Bryan KB Offline
                                    Still planning out the treads. Those will probably be last.
                                    Inner springs and central "hub" added.
                                    Inner springs created same process as rim knuckles. (edit outer spring component, add inner spring half)
                                    • Bryan KB Offline
                                      Never mind. Got inspired. πŸ˜‰
                                      Believe it or not (I certainly don't) the wheel is almost done. An inner spring arch and then the outer treads and that's it! (the central support and steering column will come after)
                                      Replaced test spring outlines with a Soap bubble plug-in construct, added depth with Joint Push/Pull, then regular Push/Pull to "back-fill", then made into component, then duplicated around the rim. Remaining surfaces deleted.
                                      Pivot/knuckle joint on end connecting to rim was then added to the spring component and its editing level, instantly duplicating it for each.
                                      • Bryan KB Offline
                                        First tread plate.
                                        After the full tread assembly is completed by adding the spring arms, the large cylinder wall will be deleted, creating an open framework.
                                          A very cool washing machine! πŸ˜‰
                                          • BoxB Offline
                                            Looking good Bryan.
                                            • 1 / 4
