Texture on Curved Surface
Hello!
BACKGROUND:
SU 7 / WIN 8I'm having issues with TEXTURE on a curved Surface.
I have 4 curved corners on a building.
Only 1 looks decent though when i applied the texture -- the rest are producing some strange artifacts. (NOTE: I know that the texture in the attached image is showing 8x16 Block, but it does the same thing with 8x8 block - which will be the final texture)
As far as I know, the curves are the same radiusQUESTION:
How can I resolve this so that it doesn't look all whacked out?Thanks!
sub.
You can use the plugin ThruPaint for this.
In the meantime I did find this other method:
Projected Image on curved surface
