    WorkPlane toolbar
    4 Posts 2 Posters 618 Views 2 Watching
    • kenK Offline
      ken
      OK, I have removed all plugins from the V 2013 plugin folder except the plugins that come with a new install.
      I installed your workplane, and have the three icon, New WP, WP Disk and WP Protractor. I noticed in looking at the plugin in Clineaxes, that it appears that the CL to point and CL to Normal should use the WP toolbar. However, that is not the case. I have installed all plugin from the store.
      I am in the process of making sure all plugin that I get from the store operate before adding any plugins not from the store.
      So should Clineaxes icons show up in the WP toolbar?
      Thanks for your input.
      Ken
        @Ken
        Just to double check this is working I [re]installed the WorkPlane Tools and the the other ClinesAxes tools from the PluginStore.
        They loaded OK and did make the expected combined toolbar.
        The #WorkPlane.rb plugins should not be renamed.
        The # ensures it loads early so that the toolbar is made.
        Then when the other tools load they find the toolbar and add to it.
        If they don't find the toolbar they don't add to it...
        They should still make Plugins menu items etc...
        ๐Ÿ˜•
        • kenK Offline
          ken
          I didn't change the names. Just used the "WP" as a shortcut for the posttyping. I will reinstall and try again.
          • kenK Offline
            ken
            OK, I have it working.
            First I re-installed the plugins from the store. Still wasn't showing up correctly. Restarted Sketchup, a couple of time, still did not work. Than I tried what I did sometime ago with another plugin. I disable the plugin, clineaxes, closed Sketchup, saw that the plugin was in the disabled list and not in the plugin drop down menu. I than re-enable the ClineAxes, closed Sketchup and then restarted Sketchup, and presto, I have the full toolbar.
            Thanks TIG
            Ken
