    Push several drillings- holes at once
    25 Posts 7 Posters 6.1k Views 7 Watching
    • BoxB
      Hopefully you know about components and how to use them. If your wood beams are all the same then make them from one component and you only have to drill a few holes.
      Also, make one hole as a component and insert it into your beams and copy/move it to make an array.
      • pbacotP
        ONE Beam? Draw the circles on a 2D surface. Remove the circle surface. Copy for more empty cirles. then push pull the 2d surface around the circles.
        • ipsketchpiI
          ipsketchpi
          many thanks πŸ˜„ yes I know all these tckniques, thanks anyway. I just thought there is something much faster.
          If its allowed to dream- click to select surface with all circles on it, click to choose only circle surface and some "super push" all at onece πŸ˜„
          /IP
          • BoxB
            The plugin Joint Pushpull will do that.
            • cottyC
              cotty
              You have the PRO version so the solid tools maybe a solution (subtraction).
              Or JPP with an intersection and some fast cleanup?
              And a third way... http://screenr.com/mstH
              my SketchUp gallery
              • ipsketchpiI
                ipsketchpi
                ok, now we talk business πŸ˜„, thanks. will check that all
                /IP
                • cottyC
                  cotty
                  Something like this... http://screenr.com/ostH
                  my SketchUp gallery
                  • BoxB
                    Carsten, you don't need to extrude through and intersect, JPP uses the same inference system as normal PP so it will stop at the other side if you click that edge.
                    • cottyC
                      cotty
                      I thought so but as I tried it, the holes were not open?!
                      my SketchUp gallery
                      • BoxB
                        Works for me using JPP VectorPP
                        • cottyC
                          cotty
                          Not for me 😒
                          my SketchUp gallery
                          • pbacotP
                            My version is as fast as you describe. One push pull. I didn't make it clear.
                            • cottyC
                              cotty
                              Of course, but it is nice to have as many possibilities as possible πŸ˜‰
                              my SketchUp gallery
                              • pbacotP
                                Didn't mean your method, Cotty. This is before those posts.
                                I can't get JPP to work for this. What's the trick?
                                Oh I see Vector Pushpull, but I still get faces on the back side.
                                • BoxB
                                  Yeah it still leaves a face, but so does extruding through and intersecting, it needs to be removed either way.
                                  I only mentioned JPP in response to the question of moving more than one face at a time.
                                  pbacot, your way is naturally the fastest.
                                  • P
                                    pcmoor
                                    a DC component is another method, place, size, copy array multiply then when happy....explode..3 times
                                    one for the group
                                    one to cut back faces
                                    at last another to remove the groups and smaller components
                                    this can be achieved via right click, select context menu "explode"
                                    note afterwards it pays to purge the drawing as unused components remain attached to the file.
                                    Something else to add to the tool box?..
                                    Philip
                                    Hole Cutter 2.skp
                                    • kenK
                                      ken
                                      I have been reading this post and surprised that no one has mention "Hole in Solid" tool. I use this plugin, to make holes, trim, and modify. There are a few times it won't do what you wished, then I use the solid tools. But for a fast method of trimming things, like I-beam, you can't beat "Hole on Solid".
                                      Just learn how to use it and you will be surprised how fast you can modify your model. This plugin is really great for drilling holes in tubular members.
                                      404 Not Found
                                      (sketchucation.com)
                                      Ken
                                      • cottyC
                                        cotty
                                        Ken
                                        It's the second or third time that you bring this little DUH! to me πŸ˜‰
                                        And you are right with this every time! Thank you.
                                        my SketchUp gallery
                                          I'm kind of surprised no one has mentioned the Drill Array tool in the Wudworx toolset.
                                          You can instantly drill through or blind holes with or without countersinks or counterbores wherever you click on a face.
                                          And if you want an array of holes you can click to make a hole at one end of the array, click to put a hole at the other end of the array and hit /n, where n is the number of copies just like you would with the Move tool or you can click to make the first and second holes in the array and type Xn or *n.
                                          • kenK
                                            ken
                                            Well Dave my Duh moment for today. Did not know that you could use this tool as an array hole drill
                                            Ken
