    Push several drillings- holes at once
    25 Posts 7 Posters 6.1k Views 7 Watching
    • cottyC
      cotty
      Not for me 😒
      my SketchUp gallery
      • pbacotP
        My version is as fast as you describe. One push pull. I didn't make it clear.
        • cottyC
          cotty
          Of course, but it is nice to have as many possibilities as possible πŸ˜‰
          my SketchUp gallery
          • pbacotP
            Didn't mean your method, Cotty. This is before those posts.
            I can't get JPP to work for this. What's the trick?
            Oh I see Vector Pushpull, but I still get faces on the back side.
            • BoxB
              Yeah it still leaves a face, but so does extruding through and intersecting, it needs to be removed either way.
              I only mentioned JPP in response to the question of moving more than one face at a time.
              pbacot, your way is naturally the fastest.
              • P
                pcmoor
                a DC component is another method, place, size, copy array multiply then when happy....explode..3 times
                one for the group
                one to cut back faces
                at last another to remove the groups and smaller components
                this can be achieved via right click, select context menu "explode"
                note afterwards it pays to purge the drawing as unused components remain attached to the file.
                Something else to add to the tool box?..
                Philip
                Hole Cutter 2.skp
                • kenK
                  ken
                  I have been reading this post and surprised that no one has mention "Hole in Solid" tool. I use this plugin, to make holes, trim, and modify. There are a few times it won't do what you wished, then I use the solid tools. But for a fast method of trimming things, like I-beam, you can't beat "Hole on Solid".
                  Just learn how to use it and you will be surprised how fast you can modify your model. This plugin is really great for drilling holes in tubular members.
                  404 Not Found
                  (sketchucation.com)
                  Ken
                  • cottyC
                    cotty
                    Ken
                    It's the second or third time that you bring this little DUH! to me πŸ˜‰
                    And you are right with this every time! Thank you.
                    my SketchUp gallery
                      I'm kind of surprised no one has mentioned the Drill Array tool in the Wudworx toolset.
                      You can instantly drill through or blind holes with or without countersinks or counterbores wherever you click on a face.
                      And if you want an array of holes you can click to make a hole at one end of the array, click to put a hole at the other end of the array and hit /n, where n is the number of copies just like you would with the Move tool or you can click to make the first and second holes in the array and type Xn or *n.
                      • kenK
                        ken
                        Well Dave my Duh moment for today. Did not know that you could use this tool as an array hole drill
                        Ken
                        • cottyC
                          cotty
                          Maybe because it's not free. But you are right, the tools looks great... πŸ‘
                          my SketchUp gallery
                          • ipsketchpiI
                            ipsketchpi
                            Where to get that "Wudworx toolset" ?
                            /IP
                            • cottyC
                              cotty
                              You can follow the link one post before your question...
                              my SketchUp gallery
                                Or you could click on the link in my post.
