    [Plugin] Layers Panel 1.2.1
    672 Posts 109 Posters 202.1k Views 109 Watching
    • H Offline
      huckrorick
      Just installed Layers Panel. It says: "Your Internet Explorer version is outdated."
      I have IE10. Microsoft site says I have the latest version. Just to test I installed IE11 (beta). Still get the same message. What's up?
      • H Offline
        huckrorick
        Hi, I posted a bit ago about the outdated Internet Explorer messages.
        In spite of the message, As far as I can tell the Layers Panel is working as described. I haven't used it extensively, just tested a bit.
        I see that scenes are updated when I change a layer with Layers Panel (as you mentioned).
        I gather that you have to do that to make some of the functions work.
        It is a big problem for me. I love the idea of your plugin because I frequently have models with lots of layers (a lot) and being able to group them would be very useful.
        However, I also have fairly complex scenes with specific layers on or off. I often go to one of those scenes and turn layers on and off for various reasons (for example, I sometimes put alternate room or furniture layouts on different layers so I can see one option, then the other). When I am done testing different layers I usually want to go back to the original layers for that scene. But it seems your plugin would prevent me from doing that.
        Any thoughts about how to deal with that?
        (I'm guessing to change the way the plugin works would be very difficult or impossible).
        Huck
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          @huckrorick said:
          Weird, your IE is recognize as IE6 or 7.
          Can you open this link with Internet Explorer and take a screenshot?
          Actually, the webdialog displays a warning when it detects IE7 or below. But maybe your version is detected as "below 7" for some reason...
          Anyone having the same issue?
          Also, can you screenshot Layers Panel so I can see how it displays it?
            jiminy-billy-bob
            It might (maybe) be possible. Not sure though, and it won't be easy, so probably not soon.
              jiminy-billy-bob
              @huckrorick said:
              Try that :
              • Open Internet Explorer
              • Press "Alt"
              • Click on "tools" which should have appeared at the top of the window when you pressed alt
              • Click on "Compatibility mode settings"
              • Make sure "Display all websites in compatibility mode" and "Display intranet sites in compatibility view" are NOT checked
              Then try again to open Layers Panel
              • H Offline
                huckrorick
                @jiminy-billy-bob said:
                @huckrorick said:
                Here is the screenshot from the link.
                Also screenshot of Layers Panel. As I mentioned, it seems to be working right, but since I'm not up on all its capabilities and haven't used it other than to make some quick tests, I don't really know.
                At the moment, the problem of updating my scenes is keeping me from using it on the models where it would be most useful.
                Oops, forgot to add the attachments. Hope editing and adding works.
                • H Offline
                  huckrorick
                  @huckrorick said:
                  Try that :
                  • Press "Alt"
                  Attached is Screen shot of compatibility mode after I unchecked one item.
                  Still get the message that IE is outdated.
                    leolouie2
                    I have just downloaded this for the 1st time. Is there a way to make it recognized existing layers in the model?
                      jiminy-billy-bob
                      This is really weird. Can you open this link with Internet Explorer and tell me what the popup says ? (If you don't have a popup, this may be because of an ActiveX warning at the bottom or top of the IE window)
                        jiminy-billy-bob
                        It should do that by default.
                        Are you using Windows ?
                          jiminy-billy-bob
                          New version 0.5 beta !
                          Changelog :
                          • Displays a warning when drawing geometry to another layer than layer0
                          • New Delete button that moves content to the current layer
                          • New button to set selection's layer as current layer
                          • New button to move selection to highlighted layer
                          • Now supports Podium render
                          • Option to purge unused groups
                          • Option to hide the render toolbar
                          • Option to open Layers Panel when Sketchup starts
                          • Potential fix for rename bug
                          http://i.imgur.com/KJOyOXA.png
                          Download in the plugin store !
                          • cmeedC Offline
                            cmeed
                            Hello Again - potential bug....
                            I opened my work from last night this morning - a popup saying the new version was out - downloaded
                            • closed layer panel (as nothing had changed) -
                              -opened Layer panel again - could see there were new features - tried options, from the new pull down - nothing happened
                            • tried new 'move selection to highlighted area' didn't seem to work
                              -closed Su
                              _open SU
                            • opened layer Panel
                              -All groups gone 😞
                              Layers still present
                            But
                            'Options' and 'move selection to highlighted layer' now work as expected. and I'm supposing the rest works too
                            (also when turning off render toolbar there's a big gap at the top.... suggest this render feature goes at the bottom no need to give such high status, you're going to use it for a short period while layers all the time....just a thought)
                            No Big issue for me on this project as I've finished but you better see if anyone else has had a problem
                            Keep up the great work - Fantastic plugin has changed my work flow tremendously
                            -just thought about your 'move to selected layer' how about 'move and rename' mmmmm interesting - you might be stepping on 'rename by layer plugin' toes but maybe you could get together - they work as a great accompaniment
                            c
                            • cmeedC Offline
                              cmeed
                              updating a scene using a shortcut (in my case 'p')with Layer Panel Open now works - great stuff
                              Cheers
                              c
                                jiminy-billy-bob
                                @cmeed said:
                                -All groups gone 😞
                                This is a real problem πŸ˜• I'll need to add a debug mode so that users can check if groups are gone for good, or if there is just a bug displaying them. Could you send me the file ? (Even without geometry)
                                I was able to reproduce that, it seems to be a CSS problem, I'll release a fix soon.
                                Nope, Renderiza's plugin works great, no need to replicate the work πŸ˜„
                                  jiminy-billy-bob
                                  Cheers
                                  c
                                  Great ! Don't know what was causing that, but I'm glad you don't have the issue anymore.
                                    jiminy-billy-bob
                                    Also, I see that the menu button is invisible on IE9, I'll try to fix it.
                                    • cmeedC Offline
                                      cmeed
                                      Nope, Renderiza's plugin works great, no need to replicate the work πŸ˜„[/quote]
                                      all I'm saying is, ergonomically it would be better.... Thats all πŸ˜‰
                                        jiminy-billy-bob
                                        Can anyone confirm this ?
                                          jiminy-billy-bob
                                          New version 0.5.1 beta !
                                          Changelog :
                                          • Fix gap at the top when hiding the render toolbar
                                          • plesiosaurP Offline
                                            plesiosaur
                                            Any plans to add Thea to the Render list? Thanks
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 33 / 34
